Question about Connecticut Electric Electrical Supplies
2011 f-150 rear sliding window
Wiring
Passenger side rear window will not goup,I have had both front wiring harness replaced,pulled rubber boot back it looks like and orange and gray wire are broke,cost me 200.00+ on each front window part was...
If you have already identified the broken wire, get a piece of shrink tubing and slide it on one end, put the wire ends back together and solder them. slide the shrink tube over the repair and heat it up (usually a lighter works fine just don't melt it). After it's working again, send me the extra money
(only kidding) If you aren't good at soldering, practice on another piece of scrap wire before you try it.
May 21, 2011 | 2004 Jeep Grand Cherokee
All my gauges go down to zero fuel says empty windows dont work but the sunroof always work
Lets start with the window problem, the most common reason for all the windows to stop working is a broken wire or wires coming into the door, if you look where the door hinges are when you open the door you will see a rubber tube that the wires run inside off, remove the front and then the rear of the rubber tube, you will be able to slide it back from the front and then the rear and check for broken wires, resplice the broken wires together and the windows should work, check all wires closely, as far as the gauges you may have a bad cluster or bad connection, remove the cluster and unplug the connector then connect it back and see if this helps it, if not then i would say the cluster is bad. hope this helps.
Oct 09, 2010 | 2000 Jeep Grand Cherokee
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
Jun 05, 2010 | 1997 Ford Thunderbird LX
My 2005 town and country touring drivers side power sliding door has completely stopped working. It started off slow and then quit completely. now my husband said that the drivers side rear window wont...
for the sliding door,check the wiring that is housed in the plastic chain at the bottom of the door.the problem with the window may be the switch in the driver door
Nov 17, 2009 | 2005 Chrysler Town & Country
Rear Sliding Window
Sounds like your power sliding window regulator has come apart causing the grinding noise.
Aug 10, 2009 | 2002 Ford F150 Regular Cab
Toyota avalon inside rear view mirror came off of mount
sliding the rear view mirror onto the metal tab on the window. look at the part of the mirror that slides over the peice on the window. one end is open and has grooves on the side. you have to put the base of the mirror above the metal mount and flat against the window then slide it down over the mount. there may be a screw to hold it in place.
Jun 25, 2009 | 1998 GMC Jimmy
How do you remove just the rear sliding window on 06' F150
cables have come loose from sliders on rear window, would like to fix myself, HELP
Jun 15, 2009 | 2006 Ford F-150
Rear passenger window just slides how do I get the door panel off
Well first take the mirror cover off. Then the roll up window handle if its manual. There is a star head behind the handle to open the door, remove that and unplug all wiring.Then behind the handle to close the door there is a cover, it has 2 screws, take those out and the rest is just plastic door clips just pull away from the door and they will start coming off.
Mar 12, 2009 | 2000 Chevrolet Malibu
1997 - Toyota Corolla -- Rear window defog not working
On each side of the Window (Could be at top or Bottom0 There are Small Slide on Wiring Connectors. Sometimes these Get Loose. I would start There.
Jan 04, 2009 | 1997 Toyota Corolla
Electrical Supplies Logo
27 people viewed this question
Top Connecticut Electric Electrical Supplies Experts
Steve
hellics
Level 1 Expert
Gene Haynes
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
