Question about Kids II Bright Starts Bounce Bounce Baby Activity Zone Neutral
Replacement part for bright starts activity centre
Need Bracket for adjustable base
How do you set the finder scope on the Starview 150EQ. I have no adjustment options and it is not in line with the main telescope alignment. The instruction manual is totally inadequate.
Place a wide angle, that is longer focal length lens in the scope in daylight and focus it and centre on some distant object, a tree, blg, tower etc.
Then use the adjustment screws on the finder to centre it on this same object.
Change to your next higher power lens, that is shorter focal length, refocus and centre, and repeat with the finder adjustment.
Next wait for evening and a bright star or planet to appear and centre it in the finder first this time. It should be somewhere near centre in the lens also. Centre it properly in the lens and make a final adjustment on the finder.
Dec 30, 2016 | Optics
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
I have a lenovo t420 which has brightness/dim issue and can't correct it by unchecking the auto brightness
There should be a function key to adjust the brightness at the top of your keyboard my laptop is F2 or F3 so at the bottom of the keyboard is a key label FN The Function key looks like a sun with an arrow if you are lucky to have it labelled.
If this does not fix problem you may have a faulty laptop . There is a circuit called an inverter in your laptop that converts DC to a higher voltage AC to run the fluro backlight behind your laptop's LCD screen. If this inverter goes faulty you could experience the symptoms you are seeing. This would require a replacement of the inverter circuit board in your laptop by a repair service centre.
http://www.youtube.com/watch?v=fSCJzA0EBo0
http://www.youtube.com/watch?v=2Yi6GNFcP3w
http://ask.metafilter.com/92210/Backlight-or-Inverter-How-can-you-tell
Sep 05, 2014 | Lenovo ThinkPad T420 Notebook
Need to adjust the brightness. The projection is too dim to see clearly in a classroom.
Appears bulb is burning out ?
If this is a replacement bulb, is it a proper replacement ?
Not all bulbs are dim-able.
May 12, 2014 | NEC NP100 Projector
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
hi,
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
ok
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
I bought a billet alloy alternator bracket for 65 windsor 302 i need instructions to install or drawing
if you look on youtube under ..march performance ford billet pulleys.. you will see one set up the triangular bracket bolts to the side of water pump for base mount on alternator ,bolt then goes through bracket, through alternator, though spacer and threads into lower hole on the head... adjustable brace then bolts to centre top of water pump and top of alternator youtube clip shows setup clearly hope this helps
Jan 10, 2011 | Ford Mustang Cars & Trucks
The picture is not clear
go to the menu setting and select the picture setting and you can select the 3d colour management,base colour adjustment,active back light control,auto brightness sensor. thank you it might help you.
Oct 15, 2010 | Vizio L32 32 in. LCD HDTV
I broke timing belt when replacing hormonic balancer
Here are some. Hope it helps =D
Timing Marks
Diagram
TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
A/C Compressor Bracket Bolt 37 (50)
Alternator Bracket Adjuster Bolt 16 (22)
Alternator Bracket Bolt 33 (45)
Balance Shaft Pulley Bolt 22 (30)
Camshaft Pulley Bolt
2.2L DOHC 37 (51)
2.2L SOHC & 2.3L 27 (37)
Crankshaft Pulley Bolt 184 (250)
Power Steering Belt Adjuster Nut 11 (15)
Power Steering Pump Bracket Bolt 33 (45)
Power Steering Pump Mounting Bolt 16 (22)
Shift Cable Bracket Bolt 16 (22)
Timing Belt Tension Adjuster 33 (45)
INCH Lbs. (N.m)
Timing Belt Cover Bolt 108 (12)
Valve Cover Nut 90 (10)
Water Pump Bolt 108 (12)
Jun 28, 2009 | 1992 Honda Accord
Remove base from TV
Remove 4 screws holding the vertical metal bracket in place. These are located just above the bottom of the rear centre of the TV. The bracket will then slide out.
You might find it easier to remove the footplate first. Simply remove all screws from the bottom of the base. The metal plate and the plastic shield will then detach.
May 27, 2008 | Televison & Video
Color Quality PINK
no its not the flash, it is the CCD. The replacement of the CCD will solve the problem.
Oct 28, 2006 | Canon PowerShot A70 Digital Camera
Kids II Bright Starts Bounce Bounce Baby Activity Zone  Neutral Logo
Top Kids II Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kids II Toy Expert? Answer questions, earn points and help others
