Question about Compaq Presario 5000 PC Desktop
Compaq Presario 5000 5BW i just Rebuilt it added more ram cleaned it its working 100% brand new i am Pretty much a computer genuis usually i can CRACK passwords easy But i was just working on my old computer i have a custom made one 5k$ :P anyways im giving it to a friend i added Parts to it like new Hard Drive new Monitor Chip new Linksy wireless chip new Plugs and Wires Everything is working 100% fine Diagnostics on it runs great Perfect condition pretty much brand new store bought :P sad thing is i forgot the password i had on the old Hard Drive so i cant Remember how to Crack it instead of taking hours of my day to i was thinking you can help. i know your Dell my custom CPU is part dell :P
  • 98 Answers
Google:password removal tools,and purchase
version 4 of password removal.it costs 29.95 but its the best disk i ever bought.
Posted on Jun 15, 2009
Presario sr1710nx what type memory
Crucial.com has an excellent wizard for locating memory.
Computer memory upgrades for HP Compaq Presario SR1710NX Desktop PC...
Lists memory compatible with your machine.
Memory Type: DDR PC3200, DDR (non-ECC)
Maximum Memory: 4GB
Slots: 4icon_note.gif Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
I have also found that the memory occasionally is not recognized. To fix remove the ram and clean electrical contacts with a clean pencil eraser. (Rub the contacts to clean.) Then replace memory. (My machine failed to boot, cleaning the contacts fixed the problem.
Nov 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
Added new ram to compaq presario sr1750nx and worked fine at first.. now wont boot
Try taking the newly installed RAM out and re-seating it. If the persists you might have a bad block on the memory chip
Mar 12, 2011 | HP Compaq Presario SR1750NX PC Desktop
My compaq presario V2000 has frozen after I loaded an antivirus
Freezing is usually a symptom of failing ram. Your motherboard could also be the culprit. It is tough to effectively diagnose because memory and systemboards work so closely together. Cheapest thing to try is replace the ram, and since you are buying ram, go ahead and buy a larger amount. Install 1gig instead of 512 meg. (make sure your pc can use the memory upgrade). Replacing the ram with new ram will let you know that the memory is new, and if the issue persists, you know it is not the ram. If the issue persists after replacing the ram, that means you should replace your system board.
Oct 01, 2009 | Compaq Presario 5716 PC Desktop
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
My Compaq desktop computer has just recently started rebooting itself. I just added some RAM but its fairly easy to do so I don't feel I messed anything up installing it... Ideas?
Yeah dude, I had the same problem with my DELL. If you install more ram, sometimes (even though it has the slots) the computer can't handle it. Did you try removing the ram you added? It may work. Other thing is that you may have loose cables from the power supply.
May 09, 2009 | Compaq Presario SR1703WM PC Desktop
Adding ram do I need BIOS update see detailed question
I don't think that this will work! I think 512 is the maximum for it. May be it'll just improve speed a little but it's always risky to update BIOS on older PCs. And this 512 sticks will cost you a lot. I think you better think to buy a new PC. Good Luck!
Apr 17, 2009 | Compaq Presario 7588 PC Desktop
Compaq presario sr2109 - beeping sound/wont turn on
Actually if you hear this intermittent sound every two seconds you must check out the RAM of you laptop. If you are a bit technical you can take out the ram cleans its contact with a fibre pencil. Re put it back and restart your pc, if it continues to beep just buy another brand new strip of ram.
If this solution is ok please give weight to my solution, thanks alot
Patrick
Nov 12, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Cannot upgrade Memory on Compaq Presario 2110US
hi Rileysue ... what is the model of your HP? ... the ram modules generally have to match each other ... brand should make no difference at all .... start by removing all of the old and add one stick of the new ... you may also have to go into the BIOS each time and verify the change in ram size ... then add the next stick and so on...
Mar 30, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Wont recognize additional ram
It could be the wrong ram that u are using when i put extra ram in I make sure they are all the same brand. some boards take 2 different types of ram (speeds) i would go back to crucial with your good ram in and then do a check and see what ram your board needs
Dec 20, 2007 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Compaq Presario 5000 PC Desktop Logo
171 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
