Question about Zenith Medical
My Zenith model ZD300Y0 dehumidifier shows a reading of 01 and the bucket full light comes on. The bucket is empty and properly seated. What is the problem?
I cannot change the humidity setting up or down
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
  • 185 Answers
SOURCE: Zenith zd300y0 dehumidifier has 01
replace sensor ***'y p/n 6877a30013r
Posted on May 16, 2011
  • 1833 Answers
SOURCE: dehumidifier Zenith ZD300y0, indicates
Make sure that you have water bucket and drain hose properly connected.
You may need to replace the sensor.
Posted on May 26, 2011
mmz133
SOURCE: Zenith Model ZD300YO 30 pt
Take out bucket. Remove front cover two screws bottom left and right. Just inside lower left is a wiring harness with a clamp. Pry off and clean rust from clamp and tubing it attaches to. (if you put the bucket in and hold sensor between fingers the humidifier will start to work) Reattach clean sensor to clean copper tubing.
Posted on Aug 13, 2012
  • 4 Answers
SOURCE: dehumidifier model lhd459el bucket full
I had same problem but fortunatly had two units (one working other not) tried swapping capacitor / thermal switch with no luck, removed plug into circuit board for humidity sensor and bucket switch.now both units work, this tells me it was simply a bad connection of the board. hope this helps someone.
Posted on Sep 04, 2012
Bucket full?
Hi pull the draw out check the float is free to move then refit the draw make sure the draw is fitted correctly and flush to the machine regards jake
Jun 11, 2013 | Dehumidifiers
The message reads CH-01. The water collection full light is flashing, but the bin is empty. Can you advise
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 06, 2011 | LG LHD45EL Dehumidifier
Bucket full light blinks with display code of 01 when bucket is empty
heatman101
Jun 28, 2011 | LG LHD45EL Dehumidifier
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Medical Logo
121 people viewed this question
Top Zenith Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Zenith Medical Expert? Answer questions, earn points and help others
