Question about iHome iBT24 mini Bluetooth Speaker
Volume can not turn up
Volume is very low, can hardly hear music throw speaker
Speaker too low, hard to hear. can i adjust volume?
What phone do you have?
On most phones there are buttons on the side to adjust volume.
There are also options for volume in your device's settings, under sound.
If it is hard to hear someone during a call you can turn on speaker mode which will make the sound a lot louder.
Oct 16, 2015 | Cell Phones
Speakers bose docking station make a noise
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Sep 10, 2012 | Bose SoundDock digital music system...
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
DVD sound is very quite. All volume controls are maximum
Some laptops just have terrible speakers. My Acer's speakers are so bad that you can hardly hear them over the sound of the DVD drive spinning. I recommend investing a few bucks in a small external speaker. I personally use this speaker from Staples. Can be turned up very loud, small enough to throw into your pocket or computer, and very good sound quality.
Mar 26, 2011 | Toshiba Computers & Internet
My laptop is playing sound at a very low level. All the volume controls are turned up to the max, but I can barely hear anything through the built-in speakers or through earbuds. Toshiba Satellite A101...
Usually what happens hear is that a program such as media player or a dvd player will have its volume turned down and that overides the overall volume.
The trick is finding it. You need to open up any and all programs you have used with some kind of volume control and check they are turned up then close them.
You will never get super loud sound on your speakers but they should be easily heard. I've run across this on both my tosh laptop and a desktop.
Apr 11, 2010 | Toshiba Satellite A105 Notebook
I can't hear music through computer speakers. Speakers are functional. I can hear low volume music from turntable. What's up?
Have you selected a different setting in the audio control section of your computer? For example: wave out, instead of line in or vice versa. Is the audio control input set low?
Aug 04, 2009 | ION Audio iTTUSB Turntable
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Ming speakers
Yeah, search on Motorolafans.com, they have software available and instructions on how to install it.
May 15, 2008 | Motorola Mobility A1200
Bose cinemate acoustimass module
try taking ones apart that have the rumbling and see if theres anything loose inside
Jan 21, 2008 | Bose Cinemate Digital Home Theater System...
iHome iBT24 mini Bluetooth Speaker Logo
54 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
