Question about SATO M84Pro Label Printer
Calibration my labels are printing offline, how can i line it up or calibrate it?
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
During manual calibration of the Z4Mplus the
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels.
Roberto Martinez
Jul 07, 2009 | Zebra Z4Mplus Label Printer
Zebra 140Xill problem
Whenever you open the printhead, the Pause led will light.
If you hit the Pause button, the printer should go back on-line and resume printing (if you didn't turn it off).
If that doesn't work, try the calibration button (labels will feed out), then the Pause button, then the Feed button.
If you don't want to toss too many labels when you calibrate, the "maximum label length" (or some name like that) can be adjusted through the front panel.
Label_Guy
Sep 14, 2008 | Zebra Printer 140-751-00000
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
SATO M84Pro Label Printer Logo
37 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
