Question about Kenwood Kdc-mp345u Car CD / USB Player
Speedometer will not work when radio is on, but immediately works when powered off
When the radio is turned to any setting other than standby, the speedometer will not work, nor will the cruise. However, when the radio is switched off, the speedometer jumps up to whatever speed i am going and the cruise will work.
    Novelist:
  • 167 Answers
I am assuming you are reffering to the regular car radio. I don't see how a regular car AM/FM Radio could do it but on two way radios the RF kills electronic devices even to the point of shutting off someone in the lane beside you's engine. However, you only have AF coming out of the radio. You might try placing some Aluminum foil around you speakers,careful not to short the wires out. That's the only thing that makes any sense to me. This foil will deflect the AF waves and block them from sensitive electronic equipment. You should have a filter in it to prevent this. Keep me informed bout this and did it just start out of nowhere or did you change something or do some work on something under the dash.
Col. Dana Gillespie.
Posted on Mar 23, 2014
KR-V6050 I cannot get audio to work on radio, video or any other setting. Also the red standby light stays on all the time, even when the power switch is turned off. Alan
Check the input / output connections are in the correct places. The red standby will stay on when the unit is off showing that it is ready for use. To confirm, turn the power off at the wall. The red light should go out after a few seconds.
Nov 20, 2016 | Kenwood Kr-v6050 Audio Video Stereo...
Sony hcd-gx470 manual
My Sony Mini MHC-GX470 have been working until a power outage yesterday and now it will start coming on the goes back to standby mode. I can hear it going through the system, starts the radio and immediately goes to STANDBY.
I need HELP!!!!!!!!!!!!!!!!!!!!!!!!
Jan 07, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
Hooked up a two-way radio,now speedometer, rpm, gas gages don't work
I'd check for
(1) blown fuse (owner's manual should list which fuse is for the instrument panel - may list it as IP fuse)
(2) broken wire or loose wire in area where you obtained power for the new accessory.
Where did you get power for the 2-way radio?
If you find a blown fuse, replace, and it immediately blows again, unhook the 2-way radio, replace fuse, and see if that works.
Aug 01, 2009 | 1996 Jeep Cherokee Country
Standby mode
There are three modes — standby mode, radio mode or CD mode. To enter CD mode, press the power button and then the CD button. To enter radio mode, press the power button and then the radio button. To enter standby mode, press the power button.
If you're in standby mode and press the time set button, the clock digits will blink. If they don't blink, you aren't in standby mode.
Dec 28, 2008 | TruTech Clock Radio
How do I get to standby mode?
Denon AVR-1508 Standby Issue
The problem is with one of the Channel power transistors. I have the same problem I am searching to find out how to test them to find out wich one is bad.
May 14, 2008 | Audio Players & Recorders
Convergence chips replaced, now power goes to standby immediately
Whenever you suspect you may have a solder bridge where you did not intend one, use a digital meter set on connectivity to check out whether you are getting a short. If so, most likely you need to redo it.
Doublecheck by using the same meter set on ohms reading. If it is super low, like 1-2 ohms, it's shorted. Your conductivity beeper may still sound off if it's less than 100 ohms, which may be a valid reading between 2 points on any cb.
Mr Bob
www.imageperfection.com
Sep 26, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Kenwood Kdc-mp345u Car CD / USB Player Logo
24 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
