Fujitsu k1801u connect key
Where is connect key on the keyboard?
Where is the ? mark on the p series lifebook?
left of the shift and arrow key andabove the control key you will have to press the shift key to select any key thats above another (/?)hope it helps
Oct 13, 2011 | Fujitsu Siemens Fujitsu LifeBook P Series...
My keyboard types numbers for several keys unless i hold down the function key. how do i turn off this feature/
Sounds like Num lock has been turned.
Looks for num lock on the keyboard and press it.
You may have to press FN & Numlock.
This will resolve the issue.
Apr 26, 2011 | Fujitsu Siemens Fujitsu Lifebook P7230...
My Fujitsu siemens esprimo mobile M9400 laptop screen was fade (white color). When I connect to extra monitor via monitor output, computer is working well. How can I solve this problem?
Dear User,
Good day, maybe you need to press the function key of your laptop plus(+) the split monitor key in your keyboard it is usually placed in F5 key.
Apr 16, 2011 | Fujitsu Siemens Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Fujitsu M2011 netbook keyboard/function key problem
The function key could be damaged or stuck down. If not, try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something. Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When it starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Jan 10, 2018 | Fujitsu Computers & Internet
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Hardware switch on a amilo fujitsu laptop
On some of the Amilo Models, the Wi-Fi button is actually a key combination on the keyboard. Have a look for a key with the wireless symbol on it - looks a bit like an antenna, and hold Fn while you press that key. Your Wireless should come back on.
Fujitsu's can be odd, cause the hardware button (mentioned above) doesn't actually disable the driver in Windows, just turns it off so no connections appear.
Mar 05, 2009 | Computers & Internet
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
Nov 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
