Question about Advanced Tech Infrared Heat Pure 1500 - Heater/Air Purifier
Heater question. My Heat Pro 1500 keeps going back to the 90 and shutting off, what's making this happen?
Mine keeps shutting off within minutes why
I believe I solved the problem. It has been running now without shutting off. Before it would run from 30 sec to 5 hrs then shut off. I found the contacts under the swing out unit that were very dirty and covered with lint. I was able to get a small used tooth brush in and clean off the 2 metal contacts (be careful not to bent the contacts) now its working great once again.
May 15, 2016 | Ionic Pro TURBO Air Purifier
Have a lux legacy c 153c made by aerus comes on and runs fine for maybe 90 sec then shuts off and in about 90 sec will come back on .has great suc and runs great while runing
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor.
I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off.
Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops.
I hope you post what you find out!
Jul 28, 2014 | Electrolux Band Aerus Lux Legacy Canister...
Heat pure 1500 shuts down and displays 90.
over heating its self, it could be a blocked and not getting the right air flow or the sensor for the heat control is on its way out. check the filter if this model has one remove all dust from the intake, check that the fan is working, if the motor has been making any buzzing or funny sounds this can be the problem too. buzzing is the starter motor humming or clicking the motor is failing.
Mar 23, 2014 | Advanced Tech Infrared Heat Pure 1500 -...
It keeps making a static sound. and it lights up with the sound because there is a small shock that happens ever 10 seconds in the back above the filter
That happens when the electrostatic grid needs to be cleaned. There should be instruction for cleaning the electrostatic grid in the owner's manual.
Nov 05, 2013 | Air Purifiers
Shark steam mop troubleshooting
This is a bad sign. The heating element has either come loose or the thermostat has failed to shut the heater down. Dont use it anymore. You can disassemble it and see what the damage is but the smell leads me to believe that it is damaged to the point that is should be replaced. Check the warranty to see if it is covered.
May 17, 2013 | Shark Euro-Pro Professional Steam Pocket...
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
Red...cleaninh light..
ame problem. I returned it to the store and they gave me a new one. So Far so good. My little ionic pro now keeps shutting off by itself. Have no idea why.
Jun 07, 2008 | Ionic Pro CA500 Air Purifier
Advanced Tech Infrared Heat Pure 1500 - Heater/Air Purifier Logo
29 people viewed this question
Top Advanced Tech Infrared Air Purifiers Experts
Are you an Advanced Tech Infrared Air Purifier Expert? Answer questions, earn points and help others
