Question about HP OfficeJet 7410 All-In-One InkJet Printer
No HP devices detected. HP Solutions Center will close now.
I've had a similar problem that neither HP, McAfee, or I could solve. This problem "No HP devices detected. HP solutions Center will close now." The problem occured when I downloaded McAfee "Total Protection" product. It's a good thing I only installed it on my PC and not my laptop, because my PC could no longer find my HP C7250 Photosmart printer. My Control Panel, Printers and FAX item showed only a "print to PDF file" item, where before the McAfee "Total Protection" download, my printer worked very well. The only way I could print was to email my files to the laptop and print them to the C7250.
HP's troubleshooting site has a lengthy procedure to add print drivers and TCP outbound and UDP inbound ports. McAfee Internet Security Center, version 9.0, doesn't support adding "outbound" or "inbound" ports, only local ports. I worked with HP solution site until they told me to politely "get lost", and go to the McAfee site for a fix. HP's final statement was "Use McAfee's 'Network Management' configurator to 'Allow Full Access' to the printer. After what seemed like endless McAfee "chat" sessions, I was no closer to solving my printing problem, but it was certainly McAfee's download and install of "Total Protection" that caused it. Finally McAfee directed me to their telephone call center number for further help. I spoke to a customer service person around 6:30 PM, Friday; they close for the day at 7:30 CDT, and only have hours M-F. I got no good help from McAfee on this problem or even a hint that a solution may be close. Sunday morning, and I guess out of patience after spending 5 days trying to solve this problem, I uninstalled my HP C7250 Photosmart printer from my PC, and reinstalled it using the CD install set that came with the printer. My printer connected right away and was shown as an item in Control Panel, "Printers and FAX" item. Printing from my PC now has been OK for 6 hours.
    Guru:
  • 224 Answers
Ok the next time this happens i'll tell you what to do.
add the ports as exceptions to the windows firewall in control panel and make sure the windows firewall is on even if mcafee has to be turned off.
Then click on start and click on run
in the run window type services.msc
now you shall find all the applications that run on your computer.
go to mcafee and then right click each mcafee service and select stop.
now look for hp cue and hp network device(if the printer is in a network mode)
the status should say started and automatic (not automatic delayed start)
if anyone says automatic delayed start double click whichever the device is and in the drop down menu where it says automatic delayed start select automatic and click on ok.
now try to install your printer and install your printer after the above is done.
By the way i have had customers come across this problem.
I am a supervisor for hp call in customers.
if you face any issue call in to us at 1800-474-6836 and
either I(Nalin) or an agent will help resolve your concern.
Now if u ever face this issue again
insert your cd and exit out of the autoplay menu.
open my computer right click your cd drive and select open.
go into the folder called "util"
then go into the folder called "ccc"
now find a file called l1 uninstallation and run that after the uninstallation is finished it will ask you to restart your computer.
once that is done insert the cd once again do all the above in the first paragraph.
then click on add a device and now your printer will work.
what you are doing above is instead of uninstalling the whole software your
only uninstallling the drivers that have been blocked by mcafee.
so once you finish the installation and restart your computer then mcafee will add your printer ports automatically to your list of exceptions and your printer will never stop working.
Posted on Jun 19, 2009
    Scholar:
  • 169 Answers
Whenever this problem comes up in the future and the printer is not showing in the control panel,you need not uninstall the whole printer s/w,but instead you can insert the CD and then click on add a device,it sometimes happens that printers take a dynamic IP address and do not show up.f you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
No HP devices detected. HP Solutions Center will close now.Need HP 7500 devices.
remove the incorrect 7500 driver and install hp universal driver after install have it search for your printer or manually configure it yourself which ever is easiest for you .please reboot your computer after removal of incorrect driver
Feb 18, 2014 | HP OfficeJet 7410 All-In-One InkJet...
No HP devices detected. HP Solutions Center will close now. I have installed and uninstalled still saying No HP devices detected. HP Solutions Center will close now.
Did you follow the prompts to turn on device and connect the USB cable at the correct time in the installation process? Check your USB connections and cable.
Jan 13, 2011 | Computers & Internet
HP Deskjet F4280 scanning problem
reload the whole HP software package in this PC
no PC stated nor full model number
no OS stated, what Op sys is it windows 10>? what/?
why not ask hp this. on there forum , warning the same questions will be asked, or all answers will be wrong
ask here, REAL HP, we are not HP here, we are chat box (dumbb)
https://h30434.www3.hp.com/
Aug 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
It might help to uninstall the HP devices through the Device Manager, and then restart the computer. Let the computer try to detect the HP devices and install them and the drivers needed. You might want to have any software discs handy in case you have to reinstall any software that came with the printer, etc.
Feb 12, 2009 | HP Computers & Internet
when it hangs,right click the task bar and open task manager and from the process tab stop the file wrapper.
In device manager click on view and select show hidden devices.
U will see and imaging device keep updating it and
Oct 22, 2008 | Office Equipment & Supplies
No hp devices have been detected. hp solution center will close now
hi petenam,
since you posted this 10/17/08, it's probably no longer an issue for you... but jsut in case someone else is runs acorss the same issue and comes by your post, here are a couple links for future refs (from HP's support site) that might be helpful.
hp solution center and product defaults:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00787813&dlc=en&product=441125
no HP devices detected via solution center:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00762521&dlc=en&product=441125
no devices messages running Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01529081&cc=us&lc=en&dlc=en&product=441125
general support issues link for your product:
http://h10025.www1.hp.com/ewfrf/wc/product?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us
-JW50
Oct 17, 2008 | HP Officejet 5610 All-In-One InkJet...
No HP Devices have been detected. Solutions Center will now close.
It may happen if you are using HP Scanjet 5590 scnaner on windows XP. I suggest you to completely uninstlal the scanner software and then install the version 9.0 from the below link. It is the updated version for Vista but work on XP system..
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=377689&prodNameId=377691&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=sj-49436-1
Also, please connect the scanner only when it prompts to do so.
Hope it will work and 5590 scanner works with XP.
Aug 13, 2008 | HP Scanjet 5590 Flatbed Scanner
Unistall the software you have for it now. Go to HP.com and look for Vista drivers for your printer.
May 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
387 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
