Question about Acer Aspire V5-122p-0681 11.6" Touchscreen Quad Core 6gb 500gb Windows 8
I have a Acer aspire v5-122p-0681, printer won't work
My HP d110a printer will not work
Cannot print emails from hp photosmart d110a printer
I'm not certain what is causing this, but an easy solution you might try for working around this problem would be to select all the text that you actually want to print, copy it, and then paste that text into Word Pad or another word processing program available on your computer. If you have been able to print other documents from Word Pad or another word processing program without problems then this would be a quick and easy solution that will do what you want until HP resolves the problem.
Feb 23, 2015 | HP Photosmart D110a Wireless E-all-in-one...
Printer says incompatible cartridge
If it is a new genuine up cartridge and not out of date contact hp and they will replace it. If it is an aftermarket unit it will always say that and may not work. There are good aftermarket brand and not so good.
Sep 20, 2014 | HP Photosmart D110a Wireless E-all-in-one...
I Have an hp photosmart d110a and had the cartridge refilled at costco. The printer will not work saying theta the cartridge has a problem.What can I do to get it to work?
If the cartridge has metal contacts, clean them with a slightly damp cloth and wipe over the ink head that faces the paper, too. If that doesn't work, then you may need a new ink cartridge.
Nov 25, 2013 | HP Photosmart D110a Wireless E-all-in-one...
HP D110a won't feed paper. I applied a little pressure on the feed wheel and it works, but I don't want to stand there with a screwdriver all day.
you probably might have to lubricate the feed wheel with some CRC or C227 electrical lubricant spray and just check the rubber that's spinning the feed if it looks worn and need replacing.
Good Luck and thanks for using Fixya.
G.
Aug 03, 2011 | Office Equipment & Supplies
Hp Photosmart C4780 won't recognize new ink cartridges
Switch off the printer and switch on again,Unclip the cartridges one by one and clip back in again this sometimes cleans out the connector pins.This has happened to me.
Sep 02, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
Want my hp psc 1315 all-in-one printer to work from my acer aspire one notebook
Good morning! please try to install the software driver of your HP PSC 1315 printer into your Acer Aspire One notebook, in order to have the printer operational when using the Aspire Notebook. best regards.
May 04, 2009 | Computers & Internet
Acer Aspire V5-122p-0681 11.6" Touchscreen Quad Core 6gb 500gb Windows 8 Logo
12 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
