Question about Canon Computers & Internet
Canon 0801 error
Error sending mail from imagerunner 2530
idriss47
  • 26 Answers
SOURCE: e000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Posted on Jan 20, 2009
  • 199 Answers
SOURCE: Canon imageRUNNER 2020 error E007. What is the
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
I think - The fixing film sensor is faulty.
Caution To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Posted on Apr 09, 2009
  • 1126 Answers
SOURCE: adjust volume canon imagerunner 1023iF
Press "Additional Functions" button. <common settings> should be displayed, if not press the "+" or "-" button until common settings is displayed. Press "ok". Press "+" or "-" button until "Audible Tones" is displayed. Press "ok". Walk through this submenu to locate the fax volume. Press "ok". Adjust as needed. Press ok. Press stop to exit settings mode.
Posted on Aug 15, 2009
Testimonial: "I'll give it a try. Appreciate the help."
  • 59 Answers
SOURCE: Canon imageRunner set up e-mail
This will be possible if there's a Send button ont he top line of the screen.
You should set up an email account on your emailserver. On the copier, as well as the Ipaddress, subnet and gateway addresses, set up the DNS server adress. Also in the network section on page 3/3 enter the email smtp server details.
This should now work after a reboot.
Please note I have found that within schools security can be tight so the system may be set to only send email from a computer. First port of call is the it dept.
Good luck
Posted on Sep 10, 2009
Testimonial: "thanks"
  • 114 Answers
SOURCE: Canon Imagerunner 3300G Error E000007-0000 what
E007 0000 An error in the rotation of the fixing film is detected. The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven. Main cause The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. most of the time the fixing film is torn or slipping
Posted on Apr 20, 2010
Error 0099 canon image runner
0099 : SMART PANEL Canon-IR-2520-2525-2530: A memory communication reservation has been cancelled.
Looks like it was answered here for a different printer -
http://www.fixya.com/support/t7156967-canon_ir2020i_dasnt_print_error_code
Sep 09, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Error code E000001 in canon ir 2530
E000-0001: Fixing temperature abnormal rise
Description: The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy:
- Go through the following to clear the error:
CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
- Check connection of the Connectors (Thermistor Connector and AC Connector).
- Replace the Fixing Main Thermistor (Film Unit).
- Replace the Fixing Assembly.
- Replace the DC Controller PCB (PCB4).
See Service Manual page 173 (7-3):
Canon imageRUNNER 2530 Service Manual Page 173
Dec 10, 2013 | Canon 2530 ImageRunner Copier
Setting up scan to e-mail on a new Canon imageRUNNER Advance 6065 printer. Have a Google e-mail server
communication setting
TX setting
2nd page
Edit standard Send setting
standard settings
store
file format: PDF
done (do not intialize)
Apr 27, 2012 | Canon Office Equipment & Supplies
My canon ir2570f has given me error E000225-001
Hello, this is optics related error, send me the mail on emma.servis@gmail.com for service manual
Oct 13, 2011 | Canon imageRUNNER C3200 Copier
Sir; i have a canon ir 6000i model machine
these is often sympthom when there is fixing trouble, usually when there is error code like E000, E001, E002, E003...
If you want send me e-mail on emma.servis@gmail.com for service manual.
Aug 03, 2010 | Canon imageRUNNER 5000 Copier
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
Apr 09, 2009 | Canon imageRUNNER 2020i Black and White...
Canon 8500 Imagerunner: Retrieving e-mailed documents
can you be more specific
are you trying to find the send email in your send item Box?
Sep 24, 2008 | Canon imageRUNNER 8500 Copier
Computers & Internet Logo
52 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
