11001100 decimal number?
  • 457 Answers
You can convert this in a number different of ways, all giving the same result if applied properly. However people from the olden days that still used 8-bit computers often used following:
1.Split the binary number in groups of four digits, adding leading zeros if necessary. 11001100 => (1100) (1100).
2. Given the individual bits have values 8, 4, 2, 1 when set, convert the groups individually 1100 = 8+4 = 12. In your case, both groups have the same value,
3. Multiply the value for the left group by 16 and add the right group's value:12 * 16 + 12 = 192 + 12 = 204.
It helps if you know the multiples 1*16, 2*16, ...., 15*16 by heart.
Posted on Mar 23, 2014
Can you round 3,150,000 to 2 decimal places
Huh?
To round off a number to 2 decimal places.... you would have to have a decimal. Your number of 3,150,000 implies 3,150,000.00
There is no rounding in this case. It is simply adding a decimal and two zeros after the decimal.
Semper Fi,
Z
Jun 13, 2017 | Office Equipment & Supplies
Find fractional notation for the ratio of 335 to 547.
write as decimal over one as fraction.
multiply top and bottom for number of decimal places by 10^(number of decimal places) to eliminate decimal.
Find the greatest common factor (gcf) for both numerator and denominator and divide both by this number in this case 2.
Simplify result.
30621/50000
Decimal to Fraction Calculator
Nov 10, 2016 | Office Equipment & Supplies
How can I round 0.4678476 to the nearest dollar?
When rounding, we always look at the number in the position directly to the right of the position we are interested in. In this case, the whole dollar is the number immediately to the left of the decimal, so we look at the number immediately to the right of the decimal. If this number is 5 or more, we add 1 to the number to the left of the decimal. If the number to the right of the decimal is 4 or less, we do not add 1 to the number to the left of the decimal.
In this case, the number is 4, so it rounds down to 0.
Good luck,
Paul
Feb 16, 2016 | Office Equipment & Supplies
FX 82 es scientific calculator. How I get decimal expansion of numbers?
Meaning what, exactly?
If you want a decimal representation of an exact number, press the SD key to switch from exact to approximate (decimal). If you want to expand a decimal number in powers of 10, separate all the digits, multiply every digit by a power of 10 with exponent equal to its position as counted from the decimal mark -1. To the left of the decimal mark, the exponent is positive. To the right of the decimal mark, the exponent is negative. Sum everything
Example
345.678 =3*10^(3-1)+4*10^(2-1)+5*10^(1-1)+6*10(-1)+7*10^(-2)+8*10^(-3)
Jul 21, 2015 | Casio Office Equipment & Supplies
Define algebra:decimal
Decimal is the base-10 notational system for representing real numbers. The expression of a number using the decimal system is called its decimal expansion, examples of which include 1, 13, 2028, 12.1, and 3.14159.
Each of the arabic numerals 0 to 9 is called a decimal digit, and the period placed to the right of the units place in a decimal number is called the decimal point (or, in the case that a comma is instead used for this purpose, the decimal comma).
The decimal is a way of managing numbers that has ten as a starting point, or base. It is sometimes called the base ten or denary numeral system. The word "decimal" is also used instead of the word "period" to point out the dot that is sometimes used separates the positions of the numbers in this system. Almost everyone uses this nowadays and prefers the convenience of it probably because it shows up most often in calculations in nature and has "one" as another starting point for the system. The number one is usually the easiest to work with in calculations.
You may go to the link below for decimal tutorial:
http://www.algebra1help.com/flash/noflash/3.html
Jun 16, 2011 | Computers & Internet
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
May 04, 2011 | Corporate Express CEB95005 Calculator
Convert .714285 to the fraction 5/7?
Say you have a repeating decimal number 0.714285 714285 714285 etc. You identify the period (the repeating part) and in this case it is 714285.
Y
ou count the number of decimal places in the period: here it is 6. Your equivalent fraction is
Fraction= period/(99...9) where the number of 9's in the denominator is equal to the number of decimal places in the period. For this case, that is 6.
Thus
0.714285 714285 714285 etc.= 714285 / 999999
Reduce the fraction and you will find 5/7
This technique works for a repeating decimal number where the period starts just after the decimal mark.
If the periodic part does not start right after the decimal mark there are modifications to be made.
Jan 16, 2011 | Office Equipment & Supplies
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
How to round the fig. in Excel 2007 E.g. 12350*32.75% = 4044.625 I want it to be rounded to nearer rupee. If the decimal is lesser than 50, rounded fig. should be lower Rupee if the decimal is more than 50...
The function is called ROUND. It has 2 arguments, (1) the original number and (2) the number of decimal digits. Here is the Excel's help: ROUND(number,num_digits) The number you want to round. None. num_digits The number of digits to which you want to round number. If num_digits is greater than 0 (zero), then number is rounded to the specified number of decimal places. If num_digits is 0, then number is rounded to the nearest integer. If num_digits is less than 0, then number is rounded to the left of the decimal point.
So for your case use this in a cell "=ROUND(12350*32.75%, 0)" without quotes, where I assume one or both numbers will come from other cells. -Ken
Aug 29, 2009 | Microsoft Office Excel 2007
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Mar 25, 2009 | HP 12c Calculator
77 people viewed this question
k24674
jasbo
jasbo
