Question about Husqvarna Garden
Will not start.
Hi,we've got a 560XP. It does not start. filter is clean.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 188 Answers
With this being an auto-tune saw you should have your dealer hook it up to the service tool. This will give you an idea of what is happening with the saw.
Posted on Feb 03, 2016
Hi there I've got a 05 polaris predator 500 Tory
hi try cleaning the carb or check your air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. Best of luck!
Aug 28, 2013 | Garden
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
Zanussi zwf1220w
Pressure system fault probably
Jun 17, 2013 | Washing Machines
Dryer is running WAY too hot.
Hi givn2fly
Your high temp thermostat is faulty, replace it.
Bud
Apr 04, 2013 | Frigidaire GLER341A Electric Dryer
The filter camber on top pops and the air stops coming thru the whole vacuum cleaner. checked filter and washed said filter. Still happens. It is a loud pop and the air noice is loud. It pops when I pull...
I'm sorry to hear you're having difficulties with your DC15. From what you've described, it sounds as if the relief valve is activating - if you've already washed the filter, it may be activating due to a blockage in the machine. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=813&product=DC15-SY-STD
Although I note you've already washed the filter, you may want to take a look at the video below to make sure you've cleaned it as recommended. In normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you'd like any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Jan 23, 2012 | Dyson DC15 All Floors - The Ball Bagless...
My Dyson pet is overheating and shutting off autimatically. cleaned filter what else?
Sorry to hear you're having difficulties with your DC14 Animal. Like most Dyson cleaners, your DC14 is equipped with a safety device which shuts off the cleaner if it starts to overheat. If you've already washed the filter, it may be overheating due to a blockage. The easiest way to check for and remove any blockages is to follow the steps shown in our online guide:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ANIMAL_US
Although you've already cleaned the filter, you may find it helpful to take a look at the video linked below to ensure you're doing it correctly. The filter should be washed in cold water without any detergent, at least once every 3-6 months. Always ensure it's totally dry before replacing it - this may take up to 12 hours.
http://www.dyson.com/support/help.asp?article=1461&product=DC14-ANIMAL_US
By clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
Aug 29, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dryer won't work! The light works and the lint
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Dryers
When I start the wash cycle, the hot water just barely drips into the tub. I've taken off the hose and the filters are clean. I've also removed and cleaned the tube that actually goes into the...
This is symptomatic of a malfunctioning water control valve- the hot water one. Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Filter getting pluged up;dishes not coming out clean. bought new filter starting to do the same.
Hi,welcome to FixYa.
Based on two things you mentioned ( replaced filter because the old one was badly plugged & new one starting to have similar issues ) leads me to wonder, does the unit heat the water.
I ask because if it does not, the detergent will never disolve properly, hence clogging up the sump, filters and everything else with un-disolved detergent.
Does the normal wash generally take 2hrs or more to complete ?
This would also explain the dishes not cleaning very well...or at all.
If you can answer any of these questions I`ve brought up and confirm the model number, I can assist you in solving this issue once and for all.
I`ll watch for your reply.
macmarkus :)
Jul 13, 2010 | Bosch Integra® 500 SHX46L Built-in...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
