Question about Sanyo DP19649 LCD TV
Make my phone remote
Cant seem to locate an app to make my samsung the tv remote can u help?
Lost my fire stick remote. can my phone be used as a remote?
apparently it can!
Amazon Fire TV (Stick): How to Use Your Phone as Remote Control ...
streaming-blog.com/amazon-fire-tv-stick-how-to-use-your-phone-as-remote/
  1. Cached
  2. Similar
Sep 13, 2015 - Make sure that the Phone with App and the Fire TV are connected to the same Wi-Fi network. ... Enter this code on your Phone. Done. You can see all of the remote apps that are paired with your Amazon Fire TV device under "Settings > Controllers and Bluetooth Devices > Fire TV Remotes".
Amazon.com Help: Download and Pair the Fire TV Remote App
https://www.amazon.com/gp/help/customer/display.html?nodeId=201640980
  1. Cached
  2. Similar
Fire tablets (with a microphone); Amazon Fire phone; Android 4.0 or higher ... Note: The Fire TV Remote App is compatible with Amazon Fire TV devices with ... settings on your router, you need to enable Multicast support to use the app. If you're not sure how to manage these settings, your router manufacturer will be in the ... Lost my fire stick remote can my phone be used as remote Google Search
Dec 31, 2016 | Televison & Video
How to stream or get apps for my bluray player
blu ray players do not use APP's only cell phones tablets and some smart TV's.
Oct 09, 2016 | Samsung BD-C5900 Blu-ray 3D Player
Does dynex Rc-701-0a remote work on wall mounted tv Samsung
Taha I'm thinking for you to ask that question it must not be the right remote for it. Here is my suggestion if you have a samsung phone, download the App: 'Peel Smart Remote'. My samsung phone 4 operates most of my stuff in my house. Hope this is of some help. Good Luck.
Nov 23, 2015 | Samsung Televison & Video
Tv has deleted all the apps apart from web browser, It also will not give me access to log into my account, other than that the tv works fine.
Good morning to you Keith
I find Sammsung apps rather tiresome. Have you been in the menu?
  • choose Smart Hub
  • there Apps settings and
  • auto update
Electronics Appliances Tablets Laptops Phones TVs Samsung US
Sep 23, 2015 | Samsung Televison & Video
Directions for activating netflix on a samsung 4 4000 led tv
I had the same problem the bottom line is call Netflix and they can walk you through it
Netflix Customer Phone Number Shortest Wait Best Support
888-638-3549
Feb 06, 2015 | Netflix
How can I track my samsung s5 that was stolen from me that I have a lock on?
Check out Android Lost. You should be able to to download and install the app directly from the market on to your phone. (Lost Android Android Apps on Google Play). This apps allows you to remotely wipe, GPS track, display messages, activate sound and video recording, and more. I have in installed on all my devices, and has helped me on more than one occasion to locate lost phones. Of course it needs to have power and a signal to work.
Feb 04, 2015 | Samsung Cell Phones
I have a Samsung sch-r740c does it have IR capabilities
As far I can understand the cell phones do not have IR capability. You can check the features of your phone on the Samsung website.
Cell Phones
If you want to find out whether the phone can be used as a remote controller for your TV and other equipment then a) your phone should have Wifi and android / iOS capability and b) your TV should also have wifi connectivity and the TV supplier should have created an android/ iOS app for remote control through cell phone.
You can check the website of your TV / DVD/ etc manufacturer for any smart apps for remote control.
Alternatively you can use devices from other suppliers that can be used as universal remotes with cell phones.
5 Apps to Turn Your Phone into Universal Remote
As your phone is an Android smart phone you should be able to find the correct device or application provided your TV or other AV are compatible.
Aug 19, 2014 | Cell Phones
How can I connect my galaxy s3 cell phone to my tv?
How to connect Samsung Galaxy S3 to TV..
There are 3 ways to do this..
1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work.
You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV.
Note: the MHL adapter may overheat your device if you have it on and working for long periods of time.
Youtube example of MHL to TV:
How to Mirror or connect Samsung Galaxy s3 to TV
2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps.
3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link
Youtube video:
How To Use Samsung Link previously AllShare Play
Jan 15, 2013 | Samsung Galaxy Cell Phones
Sanyo DP19649 LCD TV Logo
21 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
