Question about Dual Electronics XDVD710 Car DVD Player
ON OFF SWITCH AND VOLUME CONTROL NEEDS REPLACING
WHERE CAN I GET SWITCH WHAT PART NUMBER
I have a Martin Logan Abyss subwoofer. It has a volume control that when touched explodes the volume. How do I fix this?
Actually the most likely answer is that the volume control knob (potentiometer ) needs cleaning internally or replacing
Aug 16, 2017 | The Audio Players & Recorders
How do I correct a faulty volume on a pure evoke 2 DAB radio
Most likely the audio amplifier chip needs replacing.Other wise you could try spraying "CRC 2-26" into the volume control assembly.
Sep 28, 2014 | Radio Communications
When I adjust the volume, I'll turn the knob, for instance, counter clockwise to turn it down. It will go down a couple digits and then may go up again.
hi richard, seems as if your rotary volume control internal switch pins are wearing out. this is a typical problem on many units that use rotary/digital encoder volume controls. before replacing the control clean the face pins, or have the pc board checked for moisture damage, or have the solder joints checked on the volume control. cheers.
Jun 23, 2012 | Kenwood KDC-322 CD Player
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
Jun 21, 2012 | Blaupunkt RPD-545 CD Player
Help i have a problem on my LA32C450, when i turn on the power,volume was up and up.The lamp indicator was blinking and display appearing volume graphic.And it can't be turn of.I try to change the...
The volume up button on the set is likely bad (may look ok) Someone needs to open set and disable (unsolder) that switch.
With ANY of the front buttons bad in this way remote or other front controls usually will not work--No magic wand will fix this--that volume up needs to be disabled or the keyboard needs to be replaced.
Apr 03, 2012 | Samsung Televison & Video
Volume control on Insignia remote doesn't work.. Have to use cable box remote to control volume.
Your remote control may be faulty. If you can control the volume from the cable box and from the buttons on the TV - then I'm pretty convinced the remote control needs replacing.
Jan 01, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Volume control keeps going up and down when I turn down the volum
Volume Switch (Encoder) needs to be replaced professionally. Desolder the old one properly, and insert/solder the new part. Problem solved. Order part from here:
http://parts.pioneerelectronics.com/model.asp?modelNum=VSXD498
Part number asx7004
Dec 04, 2008 | Pioneer VSX-D498 Receiver
Static from left speaker when adjusting volume control
You might try replacing the connection cables. Old cables can cause the problem you have experienced.
Dec 26, 2007 | Audio Players & Recorders
Dual Electronics XDVD710 Car DVD Player Logo
27 people viewed this question
Top Dual Electronics Car Audio & Video Experts
xxxxxx xxx
Matthew Spark
Matthew Spark
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
