Question about Minnetonka Clothing Accessories
Need small band to go around wrist watch to keep strap in place
Need small band (about 1/2 inch wide) to keep wrist watch strap in place. Probably rubber.
SOURCE: watch link
HOW DO I TAKER A LINK OUT OF THE WATCH BAND
THE MAHE UIS KENNITH COLE REACTION KC3555 P93-07
Posted on Aug 11, 2008
  • 55 Answers
SOURCE: Missing piece to Luminox 3000 black rubber watch band`
Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
Posted on Nov 18, 2009
escapement
  • 2334 Answers
SOURCE: Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Posted on Mar 30, 2010
Testimonial: "Quick and informative response!"
  • 184 Answers
SOURCE: Need a new Rubber Wrist
Hi, Most Timex bands for this series can be found at this site:
http://www.watchbands.com/Category.aspx,,CategoryID,,4
They will cost you between 8 and 15 dollars.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Posted on Sep 08, 2010
watchandpen
  • 45 Answers
SOURCE: I broke the wrist band
Most Citizen Authorized dealers locally can order this band for you.
Unfortunately, most do not have the skills or Certified Master Horologist on staff to install it for you properly. If you know how to install it, or would like to attempt it you can save some money and order it directly from Citizen yourself by providing the model number and calling: 800-321-1023 extension 2.
I would recommend having a Certified Master Horologist install it for you.
The cost, as a rule of thumb, would be 50% of the original retail price of the timepiece, plus shipping and handling.
Posted on Feb 23, 2011
Testimonial: "Thank you very much... I contacted Citizen Customer Care here in CA and had already sent them the watch."
How do i adjust the band on the slimline mesh skagen watch
Step 1. On the reverse of the strap you should see a succession of ridges. You will also notice a corresponding ridge on the clasp. Sounds obvious, but once you have decided where the clasp should reside on the strap, you need to align these two ridges.
The reverse of the strap
Step 2. Get a piece of string or ribbon and wrap it around your wrist. Snip the string so that one end meets the other and measure this diameter.
Step 3. On the other end of the strap you will see the hook which goes over the clasp - you will see the next picture. From this hook the measured distance will be where the end of the string lies.
The clasp mechanism - the watch is to the right of the picture
Step 4. This is the tricky bit! Insert a small screwdriver into the hole on the main clasp part, from the right hand side and bend it down towards the strap thus opening the clasp. Do not insert a tool from the left side, under the clasp and use the bar as a fulcrum; you will bend this rod and the watch strap will not hook over it. Move the clasp to the desired position and gently locate the ridge nearest the position. Once located, press down on the open clasp until it clicks into place - voila!
Related posts:
Dec 26, 2012 | Skagen Slimline Mesh 358SGS Wrist Watch
How do yu remove raymond weil watch strap pins?
It depends on the strap as there are several different types.
But I suspect the one you have has pins that go through the whole metal wrist band.
You need a special tool that pushes out the pin, these normally only come out in one direction.
There should be very small direction arrows on the back of the strap if that is the case.
When putting them back in again they must go in the correct direction.
Look on ebay for wrist watch strap removal tool, looks like a mini vice with a small handle and pin pusher the other end.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Watches
Where can I buy a watch strap (double pin) for a Fossil FS3041?
mcdevito75 here, You can but a new strap for your Fissil watch almost any where, Ebay, or you can look for a small watch repair shop in your area as they would have the watch right there for a perfect fit. With anything else you"ll need to know the MM size of your strap. As the strap attaches to the watch case at the pins, simply measure in MM"s this is the size of the band you need, if you can only measure in Standard Measurement use the search online for conversion Inches to MM. But with a watch shop they do everything for you.
Sep 01, 2010 | Fossil FS3041 Wrist Watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
    mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
    Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
    Where can I get a replacement band (strap)for my Nike watch model WA0021-002
    mcdevito75 here, Your Best bet may be a small watch repair shop in your area fopr a new watch band / strap.
    Jul 28, 2010 | Nike Oregon WA0021-013 Wrist Watch
    I need replacement band for a 433LSLB Skagen watch. Please advise.
    mcdevito75 here, BEST BET, look for a small watch repair shop in your area for a replacement strap or original strap from Skagen.
    Jul 12, 2010 | Skagen 105LTX Wrist Watch
    Band removal
    There are two little pins on the strap. They need to be pushed to the side to release the strap
    Dec 24, 2007 | Nike Triax 10 WR0006-001 Wrist Watch
    Clothing Accessories Logo
    13 people viewed this question
    Top Minnetonka Clothing Accessories Experts
    SANJEEV KUMAR SURI
    SANJEEV KUMAR SURI
    Andrew Taylor
    Andrew Taylor
    Da Doc
    Are you a Minnetonka Clothing Accessory Expert? Answer questions, earn points and help others
