Question about Tefal Emeril by T-fal Electric Pressure Cooker
When it reaches the temp to cook it switches to warming
Warming comes on
Why don't the three lights come on after warming up?
If no lights then that is telling you that there is a problem with the temps..
During the event of any of the heater block going open circuit, the unit
shall not be prevented from going into ready mode when the second
thermal block reaches ready temperature.
Apr 25, 2014 | Sunbeam Cafe EM6910
Heater not blowing hot air
Hi Chris, sounds like your thermostat may be worn and not closing all the way which would cause your engine to run cool at times. If you have a temp gage it should tell you if the engine is actually warming up or not. If not I would replace the thermostat.
Mar 18, 2014 | Ford Mustang Cars & Trucks
2003 grand marquis trouble code po 128. Heater works. 100 mile trips no problem. Temp gage below C. New sensor or new thermostat?
Well code 128 is for a thermostat problem in the fact the engine is not reaching normal temp. If you have heat the engine is warming up but still may not be getting to normal range. Normal is 190 - 210 degrees.
I would replace the thermostat first and see what happens.
Jan 24, 2014 | 2003 Mercury Grand Marquis
We have a Maytag gas kitchen range. It's about 10 years old. When I have oven turned on while it is warming up and also when something is baking in it, gives off a "poof" sound every so often. ...
The igniter is probally on it's way out. You will likely start noticing it taking longer to cook or not reaching temp easily. The poof is the gas valve partially opening then the igniter finally ignites it. The flame is usually smaller or yellower.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 16, 2010 | Maytag MGR5751AD Gas Kitchen Range
Warming up will not clear
Most warming up errors are a result of the scanner going bad or the fuser not reaching temp. In either case you'll most likely need to have it serviced.
Apr 21, 2010 | Dell 1125 All-In-One Laser Printer
Intermittent hesitation at steady speed.
It could be the spark plugs, plug wires, distributor cap, rotor in the cap, or an O2 sensor. does the check engine light come on?
Feb 08, 2010 | 1992 Honda Accord
The over comes on, but wil notcome back on when more heat is need
what brand? what year? do you have spark Ignition for oven of just top. Glow ingnitor. Do you have a clock that has a setting fo keep warm or end of cook time. You could be locked in keep warm(20 +yr old oven with pilot)
Nov 21, 2009 | Washing Machines
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Tefal Emeril by T-fal Electric Pressure Cooker Logo
35 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
