Question about Kenmore HE5 Electric Dryer
Won't heat Dryer comes on, but will not heat
I have a Kenmore dryer model # 96580110 and the heat won't come on when it is operating
Your Heating element may have burned out. Repair clinic has some good repair videos, and a parts department. Sears parts direct is also another source for parts.
Nov 20, 2012 | Whirlpool LEB6200 Electric Dryer
Kenmore 90 series dryer won't heat
Take the back off and look at the heater is what I would do If your filter comes out the top the dryer breaks down like this:
If your dryer has the filter down in front then your dryer comes apart like this:
Oct 03, 2012 | Kenmore 73952 Gas Dryer
Does not heat,gas won't ignite.the glow rod comes on ,but no gas comes out to burn
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 12, 2011 | Dryers
No heat, just a slight glow coming from the heat source
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 14, 2010 | Whirlpool LER5636P Electric Dryer
How come the dryer will not heat up?
heatman101
Aug 07, 2010 | Kenmore 74602 Gas Dryer
Heat comes on and heats the drum, then it shuts off but doesn't come back on.
heatman101
Aug 01, 2010 | Kenmore 400 6943 Dryer
No heat coming from dryer
heatman101
Jun 13, 2010 | Candy CDV262 Dryer
Hi, have a kenmore gas dryer, flame comes on about
heatman101
May 17, 2010 | Dryers
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Kenmore HE5 Electric Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
