Question about D-Link NetDefend DFL-200 Firewall
DFL-200 WAN won't connect
Storefront hit by lightning now DFL-200 won't connect to WAN.  I have reset and upgraded fw.  Still no go.  Any ideas?
    Scholar:
  • 193 Answers
Might be the WAN port failure because of the lightining>so only possiblities is replace it
Posted on Nov 08, 2007
Unable to reset Dlink DFL 700 network firewall
To perform a factory reset using the reset button do the following:
Step 1: Make sure that the DFL-200/DFL-700 is on.
Step 2: Press and hold the button located on the back of the DFL-200/DFL-700 below the word Reset using a paper clip for 10 seconds.
Step 3: Release the button.
Oct 23, 2009 | D-Link NetDefend DFL-700 Firewall
DFL-200 UPnP
connect your router to computer with ethenret cable in lan port.
Then access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or 'password"
then go to advanced and enable dhcp then save settings and restart the router to take effect.
Aug 18, 2009 | D-Link NetDefend DFL-200 Firewall
Unable to map server to storage media over the internet for back
Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly.
Check your configuration level and access policy.
If its a public server you have to place it in DMZ.
Check IP settings of the server. U may require a VPN tunnel
Rate if this is helpful
Thanks
Good Luck
Jun 01, 2009 | D-Link NetDefend DFL-200 Firewall
DFL-260 Fierwall setting for Static IP
All of these info below are available in the owner manual that you can download here :
D-LINJK DFL-260 Firewall
You can either do it true command line or with the web interface.
Apr 09, 2009 | D-Link NetDefend DFL-200 Firewall
Client PC not able to ping WAN networks
Did you set reverse routing rules on the D-Link?
Dec 18, 2008 | D-Link DFL-800 Firewall
Port forwarding?
You can follow the steps on this link, click here. This is the steps on how to setup port forwarding for pc anywhere on a DFL-200. There is big possibility that the DFL-80 might have the setup configuration page as the DFL-200.
I hope this one helps.
Jul 07, 2008 | D-Link DFL 80 (DFL-80) Firewall
I need configuration aid for the DFL-210
Dear Sir/Madam,
Please check this link for more details. It may be help you.....
ftp://files.dlink.com.au/products/DFL-860/Manuals/NetDefendOS_2.12_User_Manual_v1.05.pdf
Thanks
Don't forget to rate the solution
Mar 06, 2008 | D-Link NetDefend DFL-200 Firewall
Url blocking on dfl-200
Hi Mohan143,
Zupertails here,
you probably overlooked one small thing.
In order to actually activate the blacklist, you need to add a rule in The Firwall, LAN->Wan filter.
1) Just add a new filter, name it what you want.
2) In 'Action' select 'Allow'
3) In 'Service' select 'http-outbound'
4) Click The green Apply icon
5) Click the Yellow Apply button right
6) Click 'Activate changes'
7) Wait a couple of seconds and click on the activation link
tadaah
Jan 05, 2008 | D-Link NetDefend DFL-200 Firewall
All Public IPs
In order to use your DFL-200 as a firewall, and not a router, you will need to put it into "transparent mode." This will allow you to use only public IP addresses and you will not be using NAT.
Jun 20, 2007 | D-Link NetDefend DFL-200 Firewall
NAT Traversal
NAT traversal refers to the common problem in TCP/IP networking of establishing connections between hosts in private TCP/IP networks which use NAT devices Client-based IPsec VPN connections often do not work when passing through a NAT device as the IKE and IPsec protocols were not designed to work through NAT. NAT Traversal is an add-on to the IKE and IPsec protocols that allows them to work when being NATed. NAT traversal is only used if both endpoints support it. D-Link products that currently support NAT traversal include the DFL-200, DFL-700 and DFL-1100. Note: The DFL-80 and DFL-300 do not support NAT traversal.
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Open Questions:
D-Link NetDefend DFL-200 Firewall Logo
451 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
