Question about New Haven Global Atomic Radio Control World Time Travel Alarm Clock
How do i set the time on the New Haven Global Radio Controlled Travel Clock
How can I get the correct day of the week? I can get the date-month & day, but not the correct day such as Sat when the clock says Monday.
check you have set to the correct year, and remember a leap year has one day more... note date,month stays the same but the day changes from year to year.. hope your clock has a year function?
May 12, 2016 | Seiko Global R-Wave Radio Controlled...
Cannot set time
WWVB Radio Controlled Clocks
www.nist.gov/.../radioclo...
National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
[PDF]Atomic Analog Wall Clock - La Crosse Technology
https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
ICF-218 Sony Alarm Clock - YouTube
? 1:50
https://www.youtube.com/watch?v=XTQ8zEMMNq8
Aug 4, 2012 - Uploaded by sohvintage
Jan 10, 2016 | Audio Players & Recorders
How do I change the time zone?
Radio controlled atomic clock self sets, and self adjusts automatically. This clock is very easy to use!,Daylights Saving Time on/off option; 4 Time Zones - Pacific, Mountain, Central, or Eastern,Folds into smaller size for easy storage and travel; travel pouch included,Automatically sets day, date and time; 2 separate alarms - great for weekends,Sturdy, contemporary construction. Stand folds for easy storage. 2x AAA batteries included; as shipped to U.S. Government and institutions
Oct 13, 2014 | Marathon Genuine Atomic Travel Alarm Clock...
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
How do I get my smart alarm clock to reset itself automatically since the goverment changed the daylight savings time? Or, if I buy a new one will it have the new time changes?
The Daylight Saving Time settings are not user controlled, so you cannot convert the changeovers to the new schedule - you can only change the time manually. Any new clock or clock radio with automatic settings will work on the new schedule.
Bill B
Apr 04, 2010 | Emerson Smartset Clock Radio
Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Apr 02, 2010 | NexxTech Travel Alarm Clock (63-8042)
Global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Mar 16, 2010 | Audio Players & Recorders
New Haven Global Atomic Radio Control World Time Travel Alarm Clock Logo
50 people viewed this question
Top New Haven Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a New Haven Audio Player and Recorder Expert? Answer questions, earn points and help others
