Question about Energizer Weather Ready Compact 2 LED Light WRCLD41E
Do not know how to load batteries - Energizer Weather Ready Compact 2 LED Light WRCLD41E
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Usually the flat side of the battery (negative side - ) sits on the spring of the battery pack, the one touching it will be placed in the same connection
Posted on Mar 25, 2014
Battery power good will not start
How do you know the battery is good? Have you done a load test on the battery? I had a battery work all my interior lights radio etc. And it showed 12 volts on a multimeter but as soon as I turned the car over the volts would drop to 2 to 4 volts, I would suggest performing a load test on the battery if you have not so far
Feb 20, 2014 | 1996 Honda Accord
How i know if the battery still working or damange
The best way to determine if your battery is in good shape is to bring it to a parts store or better still, a place specializing in batteries. Ask them to be sure it has a good charge and for them to perform a load test. (A load test won't work on a battery that's not fully charged).
Jan 18, 2012 | Chrysler Voyager Cars & Trucks
Slowing cranking starter motor
Since you have not indicated whether the battery has been load tested that is what should be done 1st as it and corroded battery cables and poor grounds are the common cause of a slow crank. Let me know if the battery has already been checked. Most auto parts stores like Autozone (and others) do battery load tests for free.
Nov 29, 2011 | Cars & Trucks
Battery is good but when i ride 1 mile trans and batterry light comes on and battery is dead but if i let the bike set for a day it will charge back
Something is not right. I'd start tracking the problem down by having the battery load tested. If you check the battery with a volt meter, it won't tell you much because it doesn't put a load on the battery. You say if your let the battery set for a day that it will charge back. I've NEVER seen a battery do that. Just checking a battery with an average voltmeter does not tell you anything about the battery because the meter is designed to work on electronic equipment with, not test batteries. The meter has a high impedance so as not to put a load on the circuit being tested. The only way to test a battery and know if it's any good is to do a load test on the battery. If it passes that, then you move on to the next step but first, make sure the battery is good.
Good luck
Steve
Jun 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Landlex Broadway Scooter runs fine on level, but runs out of steam on inclines local firm tested batteries (i think they said they are 34amp) test results 94% and can't seem to find problem! At least they...
Hi johnsoncarli
I have had the problem before. It can be seversl things.
1. Bad motor brushes, or the brushes have created a lot of dust on the armatures and will strain the motors to work harder and lose power faster. Also, I don't know how old the chair is, however sometimes the older motors may need to be re-wires (copper wiring).
2. This is the easiest, with a programmer, program the fastest speed (100) and lower the torque. Torque is set high for hills. and lower for flat land. THe lower the torque the farther you can go on a charge.
3. I know you said you had your batteries tested, but 94% is not a accurate reading. They need to be load tested. You can go to an auto parts store to have them load tested. If under a load, even if they show 94% they may not have enough strength to carry the chair load. I have seen new batteries that wouldn't hold a good load. If while testing the load, the voltage drops 4 or more volts, replace the batteries, not just one, both. Even if the load test says they are good, replace them. Bet that will cure the problem.
Good Luck
mimiobility
May 02, 2011 | Electric Mobility Electric Power Mobility...
P38 Battery empties in 24 hours (new battery)
Couple of things: First I would have battery load tested. (I know, you mentioned new battery. I have Disco that had new battery go bad - new. factory defect) If load test is good start at fuse panel with volt meter/test lamp and look for accessory/fuse that's drawing voltage when key is off.
Note: attached link for RAVE (free Rover service manuals for download) - http://www.landroverresource.com/
Mar 01, 2011 | 1997 Land Rover Range Rover
Replacing battery
so you know it needs one, but you dont know where it is? how did you check the charging system and load test the battery? its in the trunk, behind the right rear tire.
Jun 05, 2010 | 2006 BMW 3 Series
The battery keeps going flat every so often like it is not keeping charge
EASY FIX, EVERY LIKE 3 YEARS BATTERIES WEAR OUT, LOAD TEST THE BATTERY WITH A LOAD TESTED AVAILABLE AT TOOL STORES AND CHECK FOR WEAK DROP VOLTAGE, IF BATTERY HOLD LOAD THEN CHECK THE WIRING TO THE CHARGER , CHECK FOR LOOSE TERMINALS OR REMOVE THE ALTERNATOR AND TAKE IT FOR A FREE TEST AT AUTOZONE OR KRAGEN ITS FREE AND THEY WILL LET YOU KNOW IF ITS GOOD OR BAD OR WEAK.... LET ME KNOW
Jan 22, 2010 | 2001 Mazda Tribute
Battery loading
Maggie,
Bottom cover, use a coin to un-screw the battery cover.
Jan 06, 2009 | Minolta X-370S 35mm SLR Camera
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
Energizer Weather Ready Compact 2 LED Light WRCLD41E Logo
124 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
weirdtop
NicK Hale
Level 1 Expert
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
