Mosfet 50wx4 indicates a feature of the Pioneer car radio. It isn't a model number. One Pioneer car radio/CD player with this feature is the DEH-1500. On this model, you need to turn off the unit to set the clock. Press and hold the Source button (to the left of the preset tuning buttons) until the device turns off. Press Audio (upper right corner) repeatedly until the clock appears in the display. Use the arrow keys (Skip/Back or Left/Right) on the right hand side of the radio to select a segment of the time to adjust. Use the Up/Down arrows to set the current time. Repeat choosing the time segment and adjusting the time until both the hour and minutes are correct. Press Band or press and hold the Audio button to exit the clock setting mode.
Turn the stereo off. The volume dial has four buttons surrounding it: Left/Right, Up/Down. Press the volume dial until the hour starts blinking. Use the Up/Down buttons to set the correct hour. Press the Right button to set the minutes and use the Up/Down buttons as before. Press the volume dial again to set the time.
depending on the model. With the car on, shut off the head unit.
Press and hold either source or src, or function, or mode until a menu comes up which will allow you to set the clock as well as other functions of the radio.
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
Press source and hold until unit turns off Press function until clock appears in display That is short version you to get you there. Here is a manual for you, the clock setting is on p34
