Question about GE Spacemaker JVM1640SJ Microwave Oven
Age part WB39x1003 and part WB49x10222 compatible
Are the glass trays compatible on the above part numbers
Part number for turntable glass tray
Only two Sizes of Turntable Glass Tray , Each manufactuer has his own number, but any Microwave repairer / supplier can help you. Try Yellow pages.
Mar 11, 2015 | Microwave Ovens
What would cause the glass tray in the microwave to shatter
  • The glass tray had a hairline crack or stress fracture that was not visible
  • It got a little too hot in one area
  • The expansion from the heat caused the fracture to expand and therefore crack and break
An accidental bumping of the microwave plate on the countertop while going from the microwave to the dishwasher might set up the above situation. The spoon your seven year old left in the mac and cheese might have arced and nicked a small piece of the glass. Whatever the cause, microwave trays break and they break for a lot of reasons.
All foods cooked in the microwave produce heat. Microwaves themselves are not hot, but the foods cooked in a microwave get hot - some much hotter than others.
Even though most microwave glass trays are tempered, they are not designed to hold up under high temperatures. You will see most microwave trays stamped with the words "For microwave oven use only" This is to let us know that it's probably not a good idea to use the trays in a conventional oven.
Any air pockets, cracks or gaps in the glass can enlarge under heat. Since glass isn't very receptive to being stretched, breakage can occur.
for more you can read on this link
http://www.ebay.com/gds/Why-did-the-glass-tray-in-my-microwave-break-/10000000003014864/g.html
Aug 27, 2013 | Goldstar Microwave Ovens
What is the dimension of the rotating plate I broke mine
Here is a link to the replacement glass cook tray for your Panasonic NN-S961 microwave:
http://microwaveglasstrays.com/shop/panasonic-microwave-glass-turntable-plate-tray-f06014m00ap-p-156.html
And here is another link to that part from Sears Parts Direct:
http://www.searspartsdirect.com/partsdirect/part-number/Panasonic-Parts/Microwave-Parts/F06014M00AP/0022/568/Model-NNS961/0789/0123245?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50019470&diagramPageId=00001&productTypeId=x&searchModelNumber=NNS961&subCompDesc=Cabinet%20parts&brandDesc=PANASONIC&modelDesc=MICROWAVE&blt=11
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
As you can see from the website, the tray has the following dimensions:
Glass tray measures approximately 16 1/2 inches in overall diameter.
Outside diameter of turntable track is 10 7/8 inches.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 06, 2011 | Panasonic NN-S961 Microwave Oven
WE need a replacement glass tray
If the model number is correct, the glass carousel tray is available at repairclinic.com for about $30. The item number is 1206676. I hope this helps you.
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
Superglue and Microwaves
Absolutely not compatable with the expansion and contraction of glass as it heats and cools. I dropped my plate and was able to get a replacement on Ebay for a $12.00 including shipping.
May 10, 2009 | Microwave Ovens
Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Mar 04, 2009 | GE JVM1790 1000 Watts Convection /...
Glass tray is broken
If yours is a Magic Chef model MDC1311ST, then your part number is 3517207600 and you can order it here.
Otherwise, please reply back with your brand and model number so we can help you.
Aug 31, 2008 | Magic Chef MCD1311ST Microwave Oven
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
Need glass replacement, what is part number or size
Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
Aug 31, 2007 | Sharp R-303CW Convection / Microwave Oven
Glass Tray table size?
Visit Magic Chef online and click the Cusomter Service link at the top: http://www.magicchef.com
Apr 03, 2007 | Magic Chef MCB780W Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
