Question about Leviton R01-PR180-1LI Decora 180 Degree PIR Motion Switch Ivory
Ipp15 off switch does not turn off light
Led light toggles on and off when on/off switch is pressed but ceiling light stays on
Odd problem with ceiling fan and LED
This is a common issue with LED bulbs in the application that you have it installed in, When you changed the socket it reset the unit. Most of those wont ever see an LED because the LED wont draw enough current. Then control box depends on a current draw in order to stay on. LEED bulbs don't have enough current draw.
Oct 12, 2017 | Dryers
Tip
DEI viper alarm acting up? cant get alarm to work, Read on
ALARM TROUBLESHOOTING TIPS
(This guide may provide help on temporarily disabling a alarm until a repair can be made)
If your alarm goes off constantly or does not armed by itself:
Does the alarm arm and disarm properly? If it does proceed, if it doesn't, then have it checked by your installer.
1. Check and make sure your dome light is not staying on. If it is make sure all doors are closed and/or the dome
light switch is not turned on.
2. Check your sensor. Make sure they are not too sensitive. They can cause false alarm and also cause the system
not to arm by itself.
3. The alarm current sensing might be detecting voltage drop from the battery of the car or current draw from an
equipment (maybe left on).
If your car won't start check the following:
1. Does the alarm arm and disarm properly. If it does chances are is not the alarm.
2. When you try to start the car the alarm goes off.. It could be your battery.
3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery terminal or dead battery.
4. Everything lights up, alarm works fine, but car still won't start. I could be a bad starter, starter disable in the alarm
or check and make sure the car is in "PARK" or press the clutch all the way down to the floor.
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
To de-activate the Valet Mode do the following:
There is a push button or toggle switch to enable the alarm (to disengage the valet mode). Without knowing where this switch is you won't be able to reconnect the alarm.
2. Flip the toggle or hold the push button for at least 1 seconds no more than 2 seconds on most DEI products,
keep it pressed in.
3. Turn the ignition off.
4. The LED. light will be off.
5. Release the push button. If you have a toggle leave it alone as described in step 2.
For more info visit us online at www.lesscoelectronics.com or our weekly deals at www.lesscosales.com
We also offer free live chat too!
on Jul 29, 2010 | Car Audio & Video
My led light stay all the time on
Hi, it sounds like your alarm is in valetmode. Depending on what kind of alarm u have, this might help. Look around for a hidden toggle switch. Usually they are mounted on a pod where ur led is mounted. Feel behind it for a button, or if your led is mounted in dash look for a small toggle, culd be under dash or kick panal. If you find it, turn on the key, flip the switch all should be in alarm mode. Good luck,.
Mar 25, 2016 | Vehicle Parts & Accessories
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
Hey Guys, need some crazy help ! So here`s the deal, i have a accent 1996 5 doors, and my turn signals and brakelights ( as in not when i press the pedal , but when they are just on for the night ) and...
Turn signal are not meant to stay on. Brake lights only come on when you press the brake pedal.Then you have tail lights that are totally different from brake and signals light.they are for night use.
Feb 11, 2011 | 2000 Hyundai Accent
Describe your how to install a ipp15-1l Problem
1) First of all you need to determine what device you are replacing. Single-pole or 3-way.
Add a comment any time
Remember you can also take advantage of fixya phone service, where expert speaks to you over the phone while you are installing device. This service is not free.
2) If you are replacing single-pole switch, that is where one switch controls the Load (light fan motor)
Here are instructions for installing ipp15-11 Motion switch for single-pole replacement.
Old switch has 2 insulated wires plus bare ground wire.
Ipp15 bare copper ground wire will connect to bare copper ground wire.
Separate switch wires for testing.
Use ordinary two prong tester, tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to ipp15 screw marked BL black.
The other wire that came off switch will connect to ipp15 screw marked RD red
Hot wire is identified.
Located in back of box are white wires that are twisted together and covered with wire nut. Remove this nut.
Now test Hot wire to all other wires in box, excluding bare ground wire.
Tester lights up on neutral wires. ipp15 screw marked WH white connects to neutral wires.
If your box does not have neutral wire, then connect ipp15 WH white to bare ground wires.
4) If you are replacing 3-way switch, that is where 2 different switches control the same Load (light fan motor.
3-way switch has 3 insulated wires and a bare ground wire.
Note screw colors on old 3-way switch. Dark screw is the Load wire. The 2 brass screws are the travelers.
From the ipp15 instructions, it appears you will need Viza Coordinating Switch Remote plus a sensor device to accomplish the 3-way installation.
If you have both of these devices and want free written instructions, then add a comment and I will verbalize contents from the manual.
Also you can pay a fixya expert to talk over the phone.
5) Leviton also offers technical assistance at 1-800-824-3055
Dec 27, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Ceiling fan
mcdevito75 here, You"ll have to remove the cover close to the ceiling to get at the switch, Make sure the wall switch and fuse are out. Note the wire position and replace the switch with 1 from a hardware store. Are you sure that toggle switch is for the lights, as you should have another for the fan. Usually the wakk switch is used to turn the lights on and a toggle switch used to start the fan.
Jul 27, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Leviton R01-PR180-1LI Decora 180 Degree PIR Motion Switch Ivory Logo
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
