Question about Sony Handycam DCR-PC9E Mini DV Digital Camcorder
Want to watch on PC
How do I watch the tapes from recorder to a computer
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
How to watch the video from the camra in pc with usb cable
If you using windows 7 you can forget about this, last operating system for this old camera are win xp, you need drivers and program like video vegas or movie maker, with these program you can record with camera or record you tape in computer. Drivers you can found easly in google
Jan 05, 2011 | Sony DCR-HC20E Mini DV Digital Camcorder
On comcast i cant tape 2 shows and watch another
You can tape 2 and watch one that is recorded, it has a dual tuner to record 2 shows. you can record one and watch another channel at the same time.
Hope this helps
May 05, 2009 | Directv (R10) DTV Receiver / 70-Hours...
I have a scientific atlanta explorer 8300hd dvr that I want to offload the recordings to either an external hard drive or a pc or laptop''
The 8300DVR has a feature built in for outputting redcordings to a VCR. To output to a PC you will need a TVTuner card with RCA inputs. Pinnacle offers several products including a Hard Drive backup. You will follow these instructions below, the VCR will be your computer.
Copy a Recording to a VCR Tape
1. Connect the VCR to the OUT 2 connection on the back of the Explorer DVR.
See page 12 for more information.
2. Make sure that a tape is in your VCR and that the VCR is set to record.
3. Press List . The Recorded List
screen appears.
4. Press Move Up or Move Down
to highlight the recording you want
to copy to the VCR. Make sure to select
a program that is not currently being
recorded.
5. Press Select . The Recorded
Program Options screen appears.
6. Press Move Up to highlight “Copy
to VCR.”
7. Press Select . The Copy to VCR
screen appears.
8. Make sure your VCR is properly connected
to your DVR outputs, and press
Record on your VCR.
9. Press Start copy A . The recording
begins copying to VCR tape. The
Recorded List displays the VCR symbol
for the recording that is copying to
VCR.
Note: You can watch the copying in
progress through the PIP.
Mar 31, 2009 | Televison & Video
I cannot watch my dvd's i taped on the philips on any other dvd player
YOU MUST FINALIZE THEM BEFORE YOU PLAY IN OTHER DECKS, CHECK YOUR MANUAL
ON FINALIZING THE DISK
Dec 17, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sony DCR-HC38 not recording or playing
try to clean the video head...just forward a blank new tape 5 times...until the head is being cleaning...dont use a video head cleaner...just think using a sand paper to the head....it damaging the head
Aug 08, 2007 | Sony DCR-HC38 Mini DV Digital Camcorder
Watching videos on a computer
Yes. DVDs are easy as you probably already know, you just need a DVD capable drive and appropreate software to play. VHS tapes are another matter altogether. You'll have to purchase something that will convert the analog signal from the VHS player to a digital signal your PC can use. I have a device I use to convert VHS tapes to DVD (ADS technologies) I could use to watch tapes but the software leaves a lot to be desred.
Feb 20, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Sony Handycam DCR-PC9E Mini DV Digital Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
