Question about Dell Latitude D500 Notebook
How do you know if the charger is bad? The light comes on and there is voltage on the end.
  • 31 Answers
Well plug it in and as long as the wiring in the cables are all enclosed it should be able to provide power to your laptop. if not, the battery could be short-circuited.
Posted on Jun 14, 2009
Why wont the spot lights for vec 192 charge ?
Boy, this one is a loaded question.
Could be the charger itself that's defective.
Having a current monitor (Kill A Watt P3), comes in handy to check to see if the wall transformer / charger is drawing any current. That would determine if the charger was working to some degree. The best way is to measure the voltage coming out of the charger itself. It should be low voltage. I would use an digital auto multimeter to check the voltage. The transformer should have written on it somewhere the type of voltage (DC-direct current/AC-alternate current). Be careful not to shorted the end connector as I could damage it.
Could be the cord of the charger that is bad.
Could be the batteries themselves that are bad.
Could be the flashlight internal parts are bad.
Jun 16, 2015 | SPOT Camping, Backpacking & Hiking
Laptop charger not working
If the charger case has a power LED and its not litup then either the charger is shot or the cord to wall is bad. Wiggle cord all around and seeit the LED comes on. If it has no LED then check voltage with volt/ohmeter at the plug end that goes into laptop. Proper voltage should be on bottomof case label.
Jul 23, 2014 | Sony VAIO EA Series Notebook Computer
Worked one day wont come on power adapter light is on the charger but not on the computer
check connector at end of charger to see if voltage is present if so charger port in laptop may be bad.its normally like 19 volts dc at different amperage rating.
Aug 04, 2013 | Compaq Computers & Internet
Charger not holding charge, not turning on
You will have to verify that the charger is actually putting out the voltage it is supposed to. The input transformer could still be good while the secondary that goes to the output could be bad or a fuse or other component could be bad in the out put OR the wire from the adapter could be bad. Replace the charger with one that has the correct voltage and amperage ratings and the correct plug on the end.
Aug 04, 2012 | Vector Black And Decker High Frequency...
How can you tell if your laptop battery is dead,or that your charger is bad?
Hi, if your mains plug has a fuse, I would check the fuse, if thats ok, put a multimeter on to the end of the of the charger lead and check for around 19v, it will say the exact voltage output on the sticker on your charger.
The green light malfunction indicates a issue with the charger not the battery.
Hope this helps
Best of luck
May 31, 2012 | Dell Computers & Internet
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red...
David, If you are not getting the yellow light on the charger then you have a problem with the charger. What voltage are you getting at the batteries when charging? You can check the charger by removing the end plate where the lights are to see if there is a fuse on the output side of the charger. if there is check to see if the fuse is blown. There probably is a fuse on the other end but since the red light comes on it is good. If you plug the charger into the charger port and put your ear to it you should hear a hum coming from the charger. Hope this helps you
Sep 29, 2010 | Health & Beauty
Unit will not power on. Light on the charger does
if the light is not on, on the charger, check the fuse in the end of the car charger...the tip unscrews and there is a tiny fuse just under the tip.
if thats ok, check the fuse to the outlet you are using in your car.
if the light comes on the charger and it still wont charge, let me know and i can help you fix it.
the 3140 are known for there bad power ports.
bill
Dec 28, 2009 | Magellan Maestro 3140 GPS Devices
Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Nov 10, 2009 | Bosch Drills
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Jun 26, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Inspiron 1521 adapter vs battery
take an ohm meter you can buy for ten bucks at radio shack put the volt meter on DC volts plug the charger into the battery charger end the black lead goes tothe outside and the red goes inside, set the meter for 12 volts dv and mesure the voltage. read the voltage output on the battery charger transformer see if it's within a half volt if not the charger is bad, if it's ok then use rubbing achol and a q tip to clean the battery connectors on the computer and the battery itself, if you do not get the light then pull the battery out and hold the power button in the on postion and hold the enter key for 1 minute and try again, if the lights do not come back on your battery is dead, if the computer will still boot with the battery then the charger is working if it won't boot up the battery is dead. Got it?
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Dell Latitude D500 Notebook Logo
43 people viewed this question
Alun Cox
