Question about Sony Xplod XM-1652Z Car Audio Amplifier
My green light comes on but no soun
When i hook up every thing the green light comes on my and no sound comes out and my compacitor say 0.06
  • 631 Answers
Re: my green light comes on but no soun
If the voltage is dropping to 0.06v, there is a bad connection somewhere. It's likely a defective fuse or a corroded connection. Also check the ground connection.
Posted on Oct 31, 2007
0 characters
3 Points
Red light will not go off on my daul amp 800 watt I have it hooked up to a 1600 watt compacitor
The compactor probably crushed it! No clue as to what you are asking
Apr 16, 2015 | Car Amplifiers
A3000DB Car Audio Amplifier: I hooked it up.It played for ten mins. Now no soun...
no, check your speaker wire inside sub box check your ground wire and you might need to wire your subs in series
May 17, 2010 | Power Acoustik A3000DB Car Audio Amplifier
No power after i unhooked the wire from amp, left wire uncovered at ends for couple days tried hooking them back up and no power now. is amp blown
if you unhooked the wire from the amp while the amp was on, you may have possibly blown a fuse, or mayb a transistor or compacitor inside the amp! easy fix, just find new transistors and compacitors and soilder them on after removing old ones!
May 03, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
No sounds coming out of subwoofers
Apr 11, 2009 | Pyle PLAM2300 Car Amp
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Not sound
The only thing I can think is the +/- on the speakers are backward or no signal from remote wire....
The green power light is on I presume?
Mar 05, 2009 | American Pro VS1404 Car Audio Amplifier
Subwoofers not getting music
looks like you need to check the SOURCE of where the signal is coming it could be that your CD car stereo SUB opt. is turn off , check the menu of SOURCE and switch to SUB on , hope this helpful
Apr 28, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Smoking Amp/Fuse Blowing
Sounds like you may have a shorted switching Transistor in the switch mode power supply causing a short to ground. If you are technical enough. Remove power remove cover and do a continuity test on the transistors on the heatsink. non of them should read zero resistance between the three legs. in all connection configuration you use to hook up your meter. If one or Two or even all of them do you must replace with proper part.
Aug 02, 2006 | Legacy LA838 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
57 people viewed this question
Top Sony Car Amplifiers Experts
Tygh Duval
Tygh Duval
Are you a Sony Car Amplifier Expert? Answer questions, earn points and help others
