Question about Gateway 200 ARC Notebook
Failure to boot & operating system not found and no sound after formatting
    Sergeant:
  • 361 Answers
I hade faced same problem many time. casuse of bottiable virous. 1/ scan for bootable virouse 2/ look sound is stall or not -right mouse click on my computer ,then click wardwere.then click device manager.if yellow sign is in speaker sound is not stallp then stallproperly.go run type control click sound and oudio look setting. and also look speaker isnt on mute?
Posted on Jun 15, 2009
Rcint failure. string table id not found. '46' at line 246
let me tell what will i do if i m at your place.. i will prepare a windows 7 bootable pendrive first.. then i will forcefully shutdown windows.. then i would turn on pc & i will boot from pendrive and perform a clean install .. i will also format whole harddrive so that problem is uprooted.. try this
Nov 29, 2011 | Computers & Internet
Format whole hard drive & Re-install OS. By doing this all problem will be gone. Backup sensitive data before formatting
Nov 29, 2011 | Microsoft Windows XP Professional for PC
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
When i put it asked for format, then told me (wondows was unable to complete the format) plz how can solve the problem
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
or if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
???????????????????? hope this helps
Jan 22, 2011 | Computers & Internet
When i power on the acer aspire one laptop i get the message: for atheros PCIE controller v1.0.0.13(2008/10/15) check cable connection..! PXE-MOF: exiting intel PXE.ROM no bootable device---insert...
If you hear is a continuous clicking sound when you turn on your laptop, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
To make sure whether it is the hard drive or not, try to take it off your laptop, attach it to another computer (either internally or externally) & see if it will work or not.
Dec 07, 2010 | Acer Aspire One PC Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Dec 07, 2010 | Toshiba Satellite Laptop
When I turn it on, it makes a continuous sound for aprox 30 secs, then shows "PXE-E61 Media test failure". When working, it self-fills any empty fields with "n", not allowing any wrting...
Dec 04, 2010 | Toshiba Satellite L505-S5966 Notebook
Dell 4600 Codes??
When he turns on the computer it should for setup press (this key). It should be the the main screen showing a hard drive at device number 1 ect. If no hdd is present yes it is the hard drive.
Aug 11, 2009 | Dell Dimension 4600 PC Desktop
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
Vaio error message
This generally indicates a hard drive failure, but occasionally it's just an operating system glitch. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a fresh operating system. If you have any problems during or after the format or install, then the hard drive has failed and will need replaced.
Jul 24, 2008 | Sony VAIO GRX550 Notebook
Gateway 200 ARC Notebook Logo
189 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
