Question about JLab Audio Audio Players & Recorders
How do i access the universal mic and track control
How to utilize universal mic track control
Samsung gt s 3850 mic track is damaged so how can solve this problem
you can find your missing track nearest capayistor or risistance.from mic points.
Apr 30, 2014 | Samsung Corby 2 GT S3850
How do i adjust the tracking on a vcr using a universal remote?
With some universal remote controls, this function cannot be accessible.
Mar 29, 2013 | One For All URC-4330 Remote Control
When I set the effects to the channel for the mic, It kills mic volume
Check your mic input settings, click the "VOLUME" control (and/or sounds fron control panel)... also check and PLAY with "GAIN +20" on the settings..
Write me back on your results..and tell me your OS... question was vague..hope it helped.
Oct 18, 2012 | Tascam DP-02 8-Track Digital Recorder
I have a flat screen Sanyo Model# ctl 2054 will a universal remote control work for this tv I don't have the orginal remote control?
Yes, a universal remote control should work on this TV since all remote controls utilizes infrared sensing technology. However, not all functionalities and features of your TV can be accessed using a universal remote control, thus only the basics like volume and channel controls but some advance features like menu setup might not work.
May 26, 2010 | Televison & Video
Configuration of mic controls for VIA VT8235
NOT ALL CARD have this functionnality
or some of the files' of the drivers are not more accessible, try to reinstall soundcard drivers
http://www.majorgeeks.com/downloadget.php?id=4505&file=15&evp=7216be170eaa0a6ea7be06e810e3b4c1
Nov 26, 2008 | VIA P4MA Motherboard
I recently purchased a samson g-track usb mic. when I use it with garage band on my imac - I get static. not always, only about 1 time in 10 recordings. I have to diconnect the mic, re-connect then it...
It appears to be a problem with USB and the clock sample rate of the mic.  You need to go into your Applications/Utilities folder to find your Audio MIDI Setup.  In there you can choose the device for input and manually set the sample rate (usually 44.1K or 48K).  Keep that window open while you record, and you'll find that the mic will reset itself to another sample rate on its own... don't know why, and Samson's support is pretty non-existent, so I can't get any answers from them.  If you simply reset the sample rate in the Mac's Audio MIDI Setup utility the problem will clear itself up.  But, with Garage Band, you'll then get a very bad latency issue that will force you to restart Garage Band to reestablish a near-zero latency.  It's annoying, but it does work.  (In Soundtrack Pro I can reset it without having to restart the application.)
Nov 25, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Troubleshoot
The mic is on the left side. That's how it's supposed to work. You should set your recording software to only record the left channel on one track and the right channel on another track.
The level controls are the knobs on the front.
Apr 07, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Adobe Audition
Double click your sound icon in the lower right and corner of your system tray, or go to your control panel and sound options. What you need to do is enable the microphone playback feature. In your control panel go to Sounds and Audio Devices > click the audio tab at the top of the new window that opens > under default devices click the Volume button > this should bring up your Volume control panel. From there look at Microphone and make sure the Mute check box is unchecked. Then move the fader up to adjust sound. What this does is allows you to hear anything that the mic is picking up, through either speakers or headphones.
Dec 02, 2007 | Computers & Internet
Top JLab Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JLab Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
