Question about Dell Office Equipment & Supplies
Broken height adjuster foot for Dell M409WX projector
The front height adjuster foot won't stay up. It's a unit that screws onto the projector. Where can I get a replacement?
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: Hitachi CP-S225 projector - spec for screws
Hi Brian
The $18 footpiece you will unfortunatelly have to pay if you want the right thing.
As for the screws to mount the bracket onto the Projector , simply look right beside the hole at the bottom. Normally the size screws that you require is printed in the plastic.
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: Dell 2400mp projector
take the hex screws out of the VGA plugs ,should be 4 more screws ,good luck
Posted on Nov 05, 2008
SOURCE: I need a replacement foot for the Dell 2400mp
Contact Decision 1
Posted on Jul 14, 2009
SOURCE: When I start the projector
Well this is actually an error message that indicates that either the fan is actually failing or the temperature sensor, and or thermostat arrangement are faulty and need to be repaired.replaced
This isn't a too uncommon event.. Hopefully it will be a temperature sensor fault, and a replacement will sort the problem out?
If you wish to DIY, then you will need to obtain a service manual, (I have had a look on the 'net and have been unable to find one, so you may need to approach the manufacturers direct?) to enable you to order the faulty parts by number, and also how and where to locate the faulty parts and remove/replace/repair.
It maybe best though in my professional opinion, to contact a local or head office from Dell, and ask for a referral to an authorised service center. When in contact here simply first only ask for a "Quote" as to the prospective repairs and costings etc, and go from there? This way one can make an informed decision, at the least.
Posted on Aug 02, 2011
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Broken foot on Olympus vp-1 projector
So is the problem that the projector is now uneven and won't stand as you want?
I have a projector myself and often use other items underneath one of the sides to help me to line it up. I use poker chips believe it or not.
but as a more permanent solution I would try and remove the broken foot, place a tight fitting rawl plug in the hole left and screw a screw into the hole slowly until it fits to the size you want.
I know this is a very DIY solution but it's what I would do.
Dec 14, 2011 | Olympus VP-1 Multimedia Projector
When I start the projector Dell M409WX..lamp lighten properly but one msg comes as "Fan Failed" and it gets shutdown. A blinking amber TEMP light indicates that the projector fan has failed and...
Aug 02, 2011 | Dell M409WX Projector
My projector is overheated with temp light flashing. how can I fix it?
If only the TEMP light is flashing, then it means the fan has broken down. You will need to send it to Dell to get it fixed.
May 09, 2011 | Dell M409WX Projector
The monitor connected to a docking station will not resize after using laptop with an InFocus projector
The inFocus projectors typically force a lower screen resolution - you have to go back and reset the monitor to it's proper resolution. Only takes a few seconds - go onto a blank area of your desktop, right click, select properties, settings, then adjust the resolution. Hope that helps - I've had the same thing happen when using a projector, and have never been able to have the screen automagically "readjust" after using the projector...
May 19, 2009 | Dell 2007FPW UltraSharp 2007FP 20.1-inch...
Height adjustment on power head
Generally, there are screws that hold the beater bar onto the vac head.  Loosen them, remove the glop that got in there and you should be okay.  If you remove the screws, note the location of all parts...Digital cameras are great things. If you forced the adjustment, you may have broken or bent something.
Nov 29, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Oct 09, 2008 | Dell 2200MP Multimedia Projector
Hi Brian
Apr 15, 2008 | Office Equipment & Supplies
Singer 6038
The presser bar is not moving, there is a set screw that controls the presser foot height on the bar, it may be to tight. Take the side cover off, and look for the presser bar, the set screw unit should be facing you. Unscrew it and see if the presser bar handel will now move.
The presser bar height should be set at 7 mm. To make an adjustment loosen the set screw. From the top of the machine, press down firmly on the presser bar and then secure the set screw.
Apr 07, 2008 | Singer 7442 Mechanical Sewing Machine
32 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
