Question about Bosch 500 HMB5050 Microwave Oven
Trim kit removal
How do you do it?
I have gt4185skb,with a trim kit.what microwave can I buy using the same trim kit in black ?
any black microwave of the same size. Take the trim kit to the shop. Black is out, stainless steel is in though.
Nov 19, 2017 | In Microwave Ovens
HOW DO I GET INSTALLATION INSTRUCTIONS FOR A TRIM KIT FOR GE JES2051DNWW?
Installation instructions can be found on this page:
sears com
or select different trim kit and get instructions:
Ge Microwave Trim Kit
Feb 28, 2015 | GE Microwave Ovens
I have a built-in Kichenaid microwave model KCMS2055sss2. When I try to heat something, while the lights come on, the magetron sound does not come on. Yesterday, opening and shutting the door fixed the...
The enclosure kits do come off and under neath is a regular micro wave and I then you can remove the cover to the microwave and all the usual parts will be under neath. The kits hide there screws in all different ways the screws are small. The Trim kit it self probably clips on over the screw plates that hold it in place. Probably from the bottom, Check out this link to see a generic trim kit. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40303.pdf
May 25, 2014 | Microwave Ovens
Remove trim kit to get to microwave
feel your way around with a fine blade
Mar 29, 2014 | LG Microwave Ovens
Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Nov 21, 2008 | GE JE1640 Microwave Oven
Trim Kit for Over stove GE Spacemaker 1800
i think i am having the same problem, i spilled a cup of coffee inside of the microwave as i was reaching to get it and the turntable stopped rotating since then. what do you think could be the problem and how could i fix it?
Oct 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Looking for a G.E. microwave trim kit
Your best bet is to call GE Parts & Accessories at 1-877-959-8688
(Mon-Fri 7am - 6pm CST, Sat 7am-4pm CST)
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | GE JVM1790 1000 Watts Convection /...
Installation Advice
The trim kit would be passively vented. I would contact the manufacturer's customer service peoiple for details. You may also need to ask to speak to a technician if the customer service folks can't fully answer your inquiry. See http://www.baumatic.co.uk
Apr 18, 2007 | Baumatic BTM25SS Convection Microwave Oven
TRIM KIT INSTALL
Phone these guys at maytag - sorry info is not available online 1-800-688-9900. Hope this helps :)
Mar 09, 2007 | Maytag MMC5000 Microwave Oven
Bosch 500 HMB5050 Microwave Oven Logo
96 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
