Question about Samsung RF267AERS French Door Refrigerator
Right 8 on refrig/power cool button is blinking and won't reset
Power outgage and when the power came back could'n reset the control panel
    Sergeant:
  • 213 Answers
Samsung 8888 Display Panel.
To reset, press, Energy Saver & Display Panel buttons, simultaneously, and hold for 10 seconds. A beep will occur. The refrigerator will run diagnostics from there. Replace all your favorite settings.
No worries the refrigerator defaults to preprogrammed cooling and freezing after the power comes back on. Your water dispenser and the rest of the extras are dependent on the command prompt display. I placed these directions in copy within the pages of my favorite cook book. Never to be without the solution again.
Posted on Mar 23, 2014
SOURCE: power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Posted on Aug 15, 2009
reyjoshua07
  • 1157 Answers
SOURCE: after a sever thunderstorm and a power outage of 7
Hi b_marquis,
To reset the unit just hold down the Power cool and Power freeze button for about 10-20 seconds. This will reset the machine and it should start again.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 16, 2011
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
  • 489 Answers
SOURCE: After a power outage, the control panel on front
The control board went into self diagnosis when the power was applied. It found an error in one or more of the systems. You will need a qualified technician to come out and see what the problems is. To bypass this problem for now, press the "Super Freeze" button and the "Super Cool" button together for 6 seconds simultaneously. This operation will put the refrigerator back to normal operation till the power is interrupted again. Good luck.
Posted on Jun 19, 2011
imufo2
  • 3773 Answers
SOURCE: Hello : I have a Samsung refridgerator about 8
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 07, 2011
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
My GE refrig. won't turn cool. control panels are blinking.
replace the main boarde located in the lower rear area of the unit behind a panel new board # G.E. 55x10942
Aug 07, 2011 | Refrigerators
Where is the reset botton on a samsung rfg297 refrig fridg is totally out
There isn't one. If you had a brief power loss unplug it for 20 minutes and then plug it back in. It should restart. If this does not work.. Press the power cool and power freeze buttons for 8 seconds and then press the UP arrow to cycle through the menu. There will be horizontal and vertical dashes in the display if there are errors. NOTE the position of ANY dashes as they appear as there are actually 13 failure indicators via those various dashes. After the last menu the unit should restart. If it does not start after the menu wait 10 minutes to see if it restarts on it's own.
If you note dashes in the temp windows I need to know what window and what positon of the digital 8 indicator it was in. (upper, center, "top or bottom right and left sides" Top or bottom lines i.e exact digit as it would appear in a digital 8 display.
There are also things like the PTC relay, run capacitor or thermal overload that can cause this.
If you have no display at all.... your most likely looking at a control panel failure.
Thanks for choosing FixYa,
Kelly
Jul 05, 2011 | Refrigerators
After a power outage, the control panel on front has only blinking lights. How do I reset the control panel to control the temperatures?
Jun 19, 2011 | Samsung RB215LASH
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Nov 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
Power went out briefly. Refrigerator control
Aug 14, 2009 | Samsung Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Cooling did not resume after power outage
you need to do a reset on the control by pressing the two top buttons until it resets.
Mar 26, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Control panel for freezer and refrigerator
Behind the back panel of the freezer section is the evaperator assembly. on the rh side of the evaperator is a sensor pack that is for the defrost cycle. there is a thermo fuse inside of this pack that is open. The fridge goes into an error state if this fuse is open. unplugging the fridge resets the system. the sensor pack will have to be replaced.
Apr 23, 2007 | LG LRBN22514ST Bottom Freezer Refrigerator
Samsung RF267AERS French Door Refrigerator Logo
333 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
