Question about Panasonic KX-TG6521B DECT 6.0 Plus Cordless Phone Digital Answering System with 1 Handset Refurbished
My panasonic DECT 6.0 plus cordless phone has a busy signal.
There is no dial tone and you can't call out or people can't call in because of a busy signal.
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
SOURCE: panasonic cordless phone no dial tone changed batteries
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Posted on Nov 22, 2009
  • 20 Answers
SOURCE: Panasonic 6.0 dect phone model # KX-TGA641 says
Remove the batteries from all of the phones, put them back in one phone at a time. If this doesn't work, try the phones somewhere else, aka a friend/employer. If they work somewhere else, the issue is with your household phone lines. If not, you should have the phone set repaired.
Posted on Mar 06, 2011
  • 5160 Answers
SOURCE: Panasonic DECT 6.0 - Inuse
I have gotten a line in use signal when there is a break in my phone wiring. Thus the first step is to determine what has failed - the phone base, handset, the cord, the jack, household wiring or outside line.
I prefer to use an old corded phone (no power brick around or other basic failure issues) with a different phone wire for diagnostics of the wiring. First plug in the spare phone at the jack where the Panasonic phone is connected. Do you get a normal dial tone with this other phone? If not, try another jack. If you still have no dial tone, find the service box where your telephone service comes in. If you are lucky, the terminals in this box will have RJ-11 jacks. In that case, plug in your test phone and check for dial tone. If there is still no dial tone, contact your phone company, they will repair the line for free.
If there is a dial tone at the service box, then it's an interior wiring problem. Check any exposed wiring for breaks. You can remove the faceplate for the telephone jacks to check for loose wires. Most faceplates use either keystones with the wires pushed into the terminal pins (need a punch-down tool to push in a wire - these are available at home improvement stores) or screw-type terminals (loosen the screw, strip the individual conductor and wrap around the screw then retighten). If the bad wire is inside the wall, you may want a professional to find and fix the problem. Your phone company will do this for a fee.
If your test phone had a dial tone at the original jack, then make sure that the base was plugged in and has power. Check if the power transformer is warm or cold. If it is cold, the transformer has failed and the base has no power. The transformer is part number: PQLV207 (output 6.5 V DC, 0.5 A) Try using the new phone cord that you used with the test phone. Make sure that the handset battery is fully charged and the handset is registered to the base. (I've had handsets loose their registration during an extended power outage.) If the battery is more than a year old, replace it. If you have a new battery and the handset battery will not stay charged, the charger may be bad.
If your phone is under warranty and has failed, let Panasonic fix it. Otherwise, you should replace the phone if the phone has failed. These units are not user serviceable.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG1033S .
I hope this helps.
(who has had the Line In Use message at the following times: road crew dug up phone line, DSL filter failed, rodents chewed on underground incoming wires. All of the above were fixed by a phone company technician. My test phone gives me fast busy signal or no sound at all since it doesn't have a line in use signal.)
Posted on Apr 23, 2011
fgrixti
  • 89 Answers
SOURCE: my panasonic cordless phone model # KX-TG2258S the
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
Posted on May 06, 2011
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Panasonic Dect 6.0 Plus has stopped working. It was working fine, but now the receiver doesn't hold a charge, and I can't get dial tone.
The rechargeable battery pack in the receiver needs to be changed, replace with genuine for optimal performance.
Jun 13, 2011 | Panasonic KX-TG1033S Cordless Phone
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG6521B DECT 6.0 Plus Cordless Phone Digital Answering System with 1 Handset Refurbished Logo
32 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
