Heating symbols for pans
Artame ware
I need a new "leg" for my society electric fry pan
You don't need anything unless the frying pan doesn't work because of the leg.
what you can do is just put an object in place of the leg it works out cheaper too
Oct 21, 2013 | Society / Regal Ware Society Regal Ware...
I'm looking for one skillet power control for Rena Ware fry electric pan Cat. 17530
Rena Ware Electric Skillets use the same control as West Bend WB-1 . The back of the Rena Ware Control does say WB-1. Mine is 1500 watt.
You can find the WB-1 eBay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.1_26_2012_12_42_14_am.jpg
Sep 07, 2011 | Precise Heat KTES2 Electric Skillet
I have this crepes n things pan from nordic ware. The inside of the pan is divided with a smaller inner ring -much like a bundt pan. How do you make a crepe in it or do I use the outside of the pan and dip...
Heat the pan rings side down. When heated, dip the flat side into a tray of crepe batter and return to the heat. It makes marvelously thin tasty crepes and you don't need to turn them over.
Jul 28, 2011 | Microwave Ovens
I want to bake a salmon loaf in a glass loaf pan in my Jen Air mincrowave/convection oven. The 4 pg. instruction manual does not give me sufficient info. In fact, there's onloy a half page relating...
I have a Panasonic Convection Micro. Yes, If you are using convection you can use metal pans. Microwave energy cannot pass through metal pans so that is why it is not good to cook in them. It could also cause arcing or reflect the microwave energy bak to the mag and over heat it. So, when possible use corning ware or Pyrex when using the microwave
Aug 17, 2017 | Jenn-Air JMV8166B 950 Watts Convection /...
I need the heat control plug for rena ware frying pan can you help please?
You can find the WB-1 ebay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.
Dec 05, 2010 | Precise Heat KTES2 Electric Skillet
What do symbols mean i lost my remote and instruction book.triangle,snowflake,pan with drop above,3 blade fan
Triangle = automatic
Snowflake= cooing only
Pan with drops = dehumidifying mode
3 blade fan = fan only (no heat/cool)
Aug 18, 2009 | Heating & Cooling
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
