Question about Vizio VO42L 42 in. LCD TV
E551i-a2 visio white screen
Set comes on complete white screen
How do you fix white vertical lines on Vizio tv.
Any horizontal or vertical lines on a LCD pane, 90% the chance that is a defective LCD panel.
Aug 01, 2017 | Vizio Televison & Video
VISIO VW32L HAS NO IMAGE ON THE SCREEN. WHAT COULD BE WRONG?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 09, 2016 | Vizio VW32L 32 in. LCD HDTV
When I went outside, tv was working. When I came back in it was off.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 04, 2016 | Vizio Original Smart tv Qwerty dual side...
Why did remote control quit working?
Replacement batteries could be defective or installed incorrectly
Oct 18, 2015 | Vizio xrt112 smart tv Remote control for...
How to fix my led screen, it has no picture i have purchase and replace the led driver.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
Aug 07, 2015 | Vizio Smart TV keyboard remote control for...
Vizio "Smart" TV not working
If the remote wasn't working you should be able to turn it on with the on button, is there any indicator lamps that light or flash or is it like its unplugged?
Nov 25, 2017 | Vizio xrt112 smart tv Remote control for...
What size screws do i need for mounting a vizio 55" to a stand?
This depends on the model being hung on the stand. The size screw to use is usually listed in the manual. Also make sure to check the maximum length of the screw or you can damage the TV.
Dec 03, 2014 | Vizio Televison & Video
Volume does not stay level it increases by it stself
This is not a fault with its remote control. The main board to your TV should be checked. Contact any service technician. If you wish to get more details, check the site linked here.
Oct 19, 2014 | Vizio xrt112 smart tv Remote control for...
Vizio VO42L 42 in. LCD TV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
