Question about HP Compaq ProLiant ML350 G3 Server
Connect HP Proliant ML350 Server.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello
I have both a HP Proliant ML350 Server for my house use.
I am not a geek at this server thing, and this is my problem.
On the back side of my Server I have 2 two power units; I have connected 220V cable to the unit and the other end to Power outlet. I connected my Keyboard, Mouse, and Monitor, and pressed I/O button. Now my server starts, at the front side, first LED light is Green, Second LED light is Red, and Third LED light is Orange, Nothing is displayed at the Monitor, and some Bip, Bip noise is herd from machine. Did I connect right, and if not, how do I connect it. Please help someone.
Thank you.
    Problem Solver:
  • 17 Answers
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Posted on Jul 10, 2009
2 Suggested Answers
RonTheTech
  • 9 Answers
SOURCE: HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Posted on Jun 17, 2009
Server no display when power on
Can you confirm that server fan is rotating or not when server power on. and which led glowing red when you power on server
Mar 15, 2014 | HP Compaq ProLiant ML350 G3 Server
Tip
Windows Server 2008 Network Driver for Proliant ML350 G3
Anyone who has tried loading Windows Server 2008 on their Proliant ML350 G3 has found that HP does not offer the network driver for this system.
BUT, the Windows Server 2003 driver for the NC series Broadcom 1gb will work! Rather than choosing the 'install' option, choose to 'extract' it, then via the device manager, manually install the driver from that location.
Happy Computing!
on Feb 04, 2009 | HP Compaq ProLiant ML350 G3 Server
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.
You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
Apr 23, 2013 | HP ProLiant ML350 G5 Server
How do you access the BIOS in a Proliant ML350 G3 server?
When you boot up your system, press F9 when prompt. It will apper usually at the top right of your monitor.
Good Luck.
C2Solutions
Nov 10, 2011 | HP Compaq ProLiant ML350 G3 Server
HP prolian red light healt, but mi hp proliant is new
Connect the Power Cords to both the Power Supply of the Server.
that's it
Aug 26, 2011 | HP Compaq ProLiant ML350 G3 Server
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
Feb 01, 2010 | HP Compaq ProLiant ML350 G3 Server
HP SERVER PROBLEM
Jun 14, 2009 | HP ProLiant ML350 G5 Server
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Apr 08, 2009 | HP ProLiant ML350 G5 Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant ML350 G3 Server Logo
858 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
