Question about Ovens
Difference between 9759243 and 9759242 - Ovens
I have a whirl pool double oven model# rbd245pdq12 an the conto board is out. Can I install a control board from a whirlpool rbd275pdq1
A lot of ovens use the same boards to reduce inventory / spare parts, but it may have different programmes. The only way to check is to look online to see what programme differences (if any) are between the 2 models and then if you already have the board is to physically check and see what differences (if any) are between the 2 boards. Look for similar part numbers or code numbers on the board and connections, plugs, etc If its the same, try it and see if it works.
Apr 13, 2015 | Whirlpool Ovens
What temp do you cook cakes in if you do not have a fan forced oven
Different kinds of cakes require different temperatures. Most cookbooks tell you what temp to use for each recipe. Same goes for cake mixes. The instructions on the box are way smarter than me.
Mar 16, 2015 | Ovens
We cannot get our oven light to turn off! Message says "close door" but it is closed!
find the door switch and figure out why it isn't operating. different brands have different switches. i can't tell what you have from here.
25439943-xipalmoknr3fbjmp51kycajc-2-0.jpg oven door switch
Feb 17, 2015 | Ovens
How do I clean inside double panes glass in oven
the door will have to removed and taken apart. Different stove ovens doors come apart differently. be careful and lay the door down on a sturdy surface when taking the door apart.
Oct 04, 2014 | Ovens
Highest temperature during self clean mode?
different brands, different models, different temps. they al range from 900 degrees up to 1300 degrees.
Apr 06, 2014 | Thermador SC302T Electric Double Oven
What is this a symbol of on my Bosch Oven?
That must have a model number. Say it. By reading user manual available for it online i can help you
Dec 21, 2012 | Ovens
Will not start. No power. Where is fuse?
Different countries use different methods for connecting up ovens. Due to the higher wattage they often have there own fuse within a special socket or more often now they will have there own trip switch which could be in the main circuit breaker for the house.
Mar 03, 2011 | Ovens
The clock keeps reverting to 12o'clock every evening at 8pm
Try using a different outlet, or different batteries (whichever is applicable).
Jan 04, 2010 | Zanussi Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
