Question about Sewing Machines
Janome bobbin problems
I have a janome 3160 qdc. The bobbin case keeps popping up. I have the JANOME BOBBINS IN IT AND IT STILL DOES IT. iS THERE A NEW FIX FOR IT. I have had this machine for 4 years and have had it in the repair shop several times. The technican did a repair that Janome sent several years age. It is still doing it. He said there was a new fix for it is that true. Also how do I put it back in when it comes out.
  • Sewing Machines Master
  • 7,365 Answers
Try getting a new bobbin case
Posted on May 07, 2014
  • 6 Answers
SOURCE: My new Janome Mini stitches too slowly
WHO CARES
Posted on Jun 16, 2008
Tally Girl
  • 1133 Answers
SOURCE: Janome 6500 Memory Craft Prosfessional
You need to ask Janome these questions, rather than Fixya I think. The plastic bobbin in the plastic bobbin holder does make a little bit of noise but I don't find it problematic.
Janome New Zealand Limited reader.gif Unit 5, 325 Ti Rakau Drive, East Tamaki, Auckland, New Zealand
TEL. +64-9-265-0250
FAX. +64-9-265-0251 black.gif E-mail
Web-site black.gif shannon@janome.co.nz
www.janome.co.nz
Providing you are using "Janome" plastic bobbins and are putting them in rotating the right way, as per the little image on the clear cover, there is no reason that the thread cutter should be dislodging the bobbin. When I use the thread cutter, my bobbin turns as thread is drawn off it, but it doesn't move upwards.
Sounds like you have already replaced the black plastic bobbin holder, is that what you mean by "Shuttle"??
My 6500 has had 2 replacement bobbin holders as I keep striking it with the needle during jam ups, which caused plastic burrs on it. On the last service the technician added a little piece that is a janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which seems to be working at holding the bobbin holder in place better. Haven't had a big jam up since he fitted it. But before this, I would dislodge the bobbin holder with a small jam, and then it would just jam and jam until I removed the needle plate with the screwdriver, removed the bobbin and bobbin holder, cleaned out all the thread fragments, then replaced the bobbin holder back into the correct position lining up the two red arrows. Then replaced the needle plate and rethreaded. I learnt to modify my sewing expectations and not try to sew really thick seams as this will just dislodge the bobbin holder again. Jeans hems were always my problem seam, I use a "Seam Jumper" now to handle going from thin to thick seam, and so far, so good.
So I would suggest you ring Janome in Akld and talk to their technical advisor a bit, describing your problem. They may suggest sending it to them for a check out to establish what is going wrong.
If you have trouble describing the issue to then you could always film it with a digital camera and send the file to them.
My only other thought is how you wind the bobbins. It is really important to wind the bobbin smoothly and evenly top and bottom, my 6500 will wind all in the middle if I let it just run, so I always wind carefully and give the thread a nudge with my fingertip to ensure it fills evening top, middle and bottom. But it sounds like you are an experienced sewer and know this already.
I'd say ring Janome and have a chat, I find if you keep your approach friendly and neutral rather than "I've never got on with this machine" that you may get some help from them at resolving this issue.
Posted on Jun 27, 2011
Tally Girl
  • 1133 Answers
SOURCE: janome memory craft 6500 sewing machine...all of a
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
Posted on Oct 17, 2011
bargainbox
  • 1388 Answers
SOURCE: bobbin for janome model 3022
You need Janome bobbins for this machine........@ any dealer
Posted on Nov 27, 2011
bargainbox
  • 1388 Answers
SOURCE: janome 10001 - bobbin winding starts okay but it
Bobbin winder sensor needs repair or replacing
Posted on Nov 28, 2011
I just bought a Janome HD3000 and need to know what bobbins to buy for it.
Try this bobbin (specialized) ' Part Number : 102261103 available at Amazon:
https://www.amazon.com/pk-Clear-Bobbins-102261103-SA156/dp/B0038RAVEC
Dec 04, 2017 | Janome Sewing Machines
Janome Memory Craft 7700qcp looking to buy more bobbins. Is their any difference between bobbin item# 200-122-005 and item# 200-122-647?
You need to check the specifications to see if your machine model is listed for the particular bobbins. If not, then don't buy them.
FWIW, it appears your machine takes Class 15 plastic bobbins, which should be easy to find at the local Janome shop, fabric store...or order online:
Class 15 Plastic Bobbins 10pk
Nov 09, 2017 | Janome Sewing Machines
I have a Janome 3160 QDC and the bobbin case has slipped. i removed it and cant insert it corectly
You may get help for that on the Janome web site, the bigger manufacturers often have a support page or download instructions
Apr 26, 2017 | Janome Sewing Machines
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
Janome 3160 qdc drop feed dogs
Look on the back side for a slide type switch.
Aug 04, 2012 | Janome Sewing Machines
Bobbin for janome model 3022
Nov 16, 2011 | Janome Memory Craft 9000 Computerized...
What size are the bobbins for the memory craft 8000? I've compared the class 15 to my original bobbin but the class 15 has a ridge that my original doesn't have...the class 15J is more like the...
You need a bobbin like this:
You can puchase them from this link
http://www.sewingpartsonline.com/bobbins-janome-kenmore-elna-102261103.aspx
Janome have one standard plastic bobbin that fits almost all their models except
1600P, 1600P-DB, 1600P-DBX and MB4.
So if you see packets of plastic "Janome" bobbins for sale they will be the right ones.
Oct 08, 2011 | Janome Memory Craft 9000 Computerized...
JI have a Janome 1100, and I have a problem with the bobbin case. I will be into my embroidery project and the bobbin case will jump and turn around sometimes causing my project to turn, and the needle to...
When you put in the bobbin case, be sure to press it in firmly until you hear it click into place. If you can't press very firmly, or are afraid of hurting your machine, simply lift the latch from the bobbin case, holding it open while you firmly insert the case into the machine. Then release the latch. You should be good to go. Hope this helps!
Jun 22, 2008 | Janome D'cor Excel 5018
Problem sitching
I had this problem when I mixed my singer bobbins with my Janome bobbins. Are you using flat bobbins or rounded ones? If they are rounded, they are your problem. Only flat bobbins work in Janome machines.
Dec 16, 2007 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
151 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
