Question about www.clockparts.com Hechinger Rc Mvt For 1/4" Dials MVTHRC7
How doo I get my Hechinger MVTHRC7 from spinning at 7 PM?
At 7 PM CST this clock movement starts spinning the minute hand clear around the entire dial no matter what you do to stop it,
Cant`t get the chimes to ring at the correct time. Not sure why this happened. i have always been able to stop the clock determine am & pm then restart
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Oct 16, 2016 | Home
How do you set pendulum to match the clock time with chime ?
Pendulum movement may be independent and can't be synchronized with the chime.
Aug 17, 2016 | Home
Setting Westminster chimes in bulova mantel clock
http://usedclockparts.com/8-clock-movement-repairs/14-fix-a-clock-that-gongs-wrong
Jul 06, 2014 | Seiko Mantel Clock
My ansonia mantle clock does not chime the proper number of chimes for the hour - strikes 7 for example at 1 pm. How do I fix this?
I suggest that you will google the following term: "ansonia mantel clock repair" the results may help you
Apr 06, 2013 | Home
Can I replace the hose on the Pronto 2 in 1??
The hose is not sold online at aftermarket parts suppliers but im sure you can contact them for assistance.....
Electrolux Home Products - North America
Address
PO Box 3900 Peoria, IL 61612
Telephone
1.800.896.9756
Monday - Friday 8:00 AM - 7:30 PM CST
Saturday - Sunday 10:00 AM - 6:30 PM CST
May 10, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I need some watch strap links for ar0113 where can i get them?
I think the only place you will get themis the maker. Below is an extract from their web site which gives you contact information. Try speaking to them to find out how you can get more links.
INTERNET CUSTOMER SERVICE Available: 8:00 am - 6:00 pm CST, Monday to Friday. 7:00 am - 10:00 pm CST, Monday to Saturday. Sunday 10:00 am - 8:00 pm. 7:00 am - 8:00 pm Monday to Friday and Saturday 8:00 am - 5:00 pm CST. 7:00 am - 8:00 pm Monday to Friday and Saturday 9:30 am - 6:00 pm CST. We are closed on company observed holidays. To place an order, or for any other questions please call 800.699.0557. Note: Your satisfaction is 100% guaranteed. All items in your order can be returned to Emporio Armani Watches for a complete refund if you are unsatisfied. Return instructions will be in the box when your order arrives.
WARRANTY & REPAIR 800-277-4013 Available M-F between 8:00am - 6:00pm CST
customerservice@emporioarmaniwatches.com
Feb 09, 2011 | Emporio Armani Watch AR0138
I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Apr 14, 2010 | Seiko Mantel Clock
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 | Watches
www.clockparts.com Hechinger Rc Mvt For 1/4" Dials MVTHRC7 Logo
27 people viewed this question
Top www.clockparts.com Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a www.clockparts.com Audio Player and Recorder Expert? Answer questions, earn points and help others
