Question about Sta Rite Pool & Spa
Heater does wants to comes on
Gas heater blower does not work
    Champion:
  • 305 Answers
You seem to have questions on here every week. are you a gas fitter by any chance?
Posted on Mar 24, 2014
Why would water come out of the air blower on my pentair master temp 400
take off top[ and see if coming from heat exchange or pressure switch leaking
Jun 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Heater goes on for about 30second and goes off and the lights goes on services heater
Heater is probably not coming on. What you hear running for about 30 seconds is the blower. After they blower comes on you should hear a obvious click. That is the igniter coming on. If you don't hear the click you have an electrical problem. If you do hear the click then either the heater is not getting gas - check the valves inside and outside the heater - or the flame sensor is not working correctly.
Good Luck
Apr 16, 2011 | Pentair MasterTemp 400000 BTU Pool and Spa...
I just replaced the control module and flame sensor. The heater fires up for about a minute then the blower comes on and it appears to blow out the flame. It will fire up again and work until the blower...
This is backwards. The blower comes on first then after the air pressure is good in the exaust it will turn on the power to the ignitor and open the gas valve. If it is doing what your describing there is something wrong with the way it is wired. But many times people will mistake the noise of the blower comming on for the flame and the sound of the gas valve and the ignitor for the blower kicking in. This is probally the case. If you have water in the fire box this is a much bigger problem with your heat exchanger and it will do damage to other components. If this is the case it is time to replace the heater. All of this is symptommatic of bad water chemestry and you will need to address this or you will damage the new heater and chemecal damage is never covered by warrenty. Good luck.
Nov 24, 2009 | Pentair Minimax NT Heater
When Spa heater is turned on,Fan comes on but burner never lights
this is typical of a dirty flame sensor.your model does not have a thermo couple.remove sesor and clean with steel wool or fine emory cloth
May 11, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Heater will not heat
If you dont smell any gas make sure that all gas valves between the heater and the main gas meter are open, and the gas valve in the heater is in the on position. Try cleaning out the nozzles that the gas comes out of. Sometimes they can build up with cobwebs.
Apr 08, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Pool & Spa Logo
52 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
