Question about Vehicle Parts & Accessories
Replaced coil and module coil still not firing
    Problem Solver:
  • 5 Answers
What is the year and make and model. Most times when a car cranks ,but does not start it is the crank position sensor
Posted on Mar 24, 2014
My 95 GMC Sonoma 2.2L has fire to the coils but not to the sparkplugs i have replaced the coils and crankshaft sensor does any know what the problem could be
What do you mean, you got fire at the coils? What testing have you done? What about the plug wires?
If you can remove one coil from ignition module, use a test lite at the primary terminals where the coil plugs into ignition module, crank the engine, does the lite pulse? If nothing, have to check voltage and ground to ignition module, if that checks out, suspect the ignition module.
Jul 08, 2017 | GMC Cars & Trucks
Coil pak not firing 97 lesabre 3.8 relaced non firing pak, didnt help.
If three coils plugged into ignition module, and one isn't firing. One coil fires two plugs, when you remove that one coil, use a test light at ignition module primary terminals, where that coil plugs in, have a helper crank it, if the light doesn't flash, replace the ignition module. You may want to disable engine so it won't start. I can't think what else it might be? I've seen this problem before, at that time, it turned out to be the ignition module that was faulty.
Jun 14, 2017 | Cars & Trucks
Why is it only firing on cylinders 2 and 3?
If you have replaced the coil that is not firing then you need to check the module remove the ignition coil that is not firing and you will see the two spades that fit into the coil that's were you test if it if it will run on two cylinders take a test light clip one side of test light to one spade use the tip of the test light to touch the other spade and running or even cranking over it should blink if not replace module
Apr 08, 2016 | Cars & Trucks
Why won't my car fire I replaced the coil and module and fuel pumps work
You checked the cap and rotor ?
And the coil wire is sparking on metal ?
Oct 08, 2015 | 1987 Ford Crown Victoria
Have a 1986 chevy celebrity tec4 an have no fire from coil ive replaced coil checked fuses an have power going to coil still no fire
ignition will trigger if signal from crank sensor, with hei spark plug tester ,read to coil wire and spark plugs wire if spark , depends wich engine
if c3i coil and module the module could be the problems you can check it before replace
hope it helps
Mar 29, 2014 | 1986 Chevrolet Celebrity
Cant get my 1992 GMC to fire
replace the ignition module or pickup coil located under the distributor cap ignition modules work when cold and will stop firing when they are warm when they r going bad
Jan 31, 2013 | 1992 GMC Sierra
Would a 2001 chryler town and country faulty engine module cause number 2 cylinder not to fire
not likely, since the engine module also fire the plug across from the #2 cylinder on the coil pack. check for spark directly at the coil, if none is found ,then most likely a bad coil pack.
Jun 11, 2012 | 2002 Chrysler Town & Country
Just firing on one coil but replaced it and still not working
You may need to replace the plug wires after many miles they become more resistive and deliver weak or no spark to the plugs. It could also be the ignition module it is common for GM vehicles in that year range to have failing modules.
Jan 13, 2011 | 1988 Buick Century
Ignition coils not getting juice...
are u asking y it doesnt get 12 volts input or are u asking y it doesnt fire? if it is receiving voltage, but not firing,then u need to replace the coil pack,if it is not getting voltage to the coil,then if it is pluged into a module the module is bad and u need o replace module and coil pack
Jun 30, 2009 | 1991 Nissan 300ZX
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
