Question about Danco Plumbing
Replace seat 3s-10h/c
Leaking fucet, ho to replace seat, where does spring go
2013 sportsman 500 gas running out the carburetor bowl from bottom. plastic tube to the ground. is the needle seat stuck?
Hi, Christopher and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2012 500 ho leaking gas from carb overflow tube
Polaris fuel leak repair
Polaris 2007 Sportsman 500 EF Service Manual
2013 Polaris SPORTSMAN 500 HO A13MH50AJ AQ AX AZ OEM Parts
Polaris Sportsman 500 HO Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 15, 2017 | GAS Motorcycles
Carb drain leaks?
This is caused by a bad needle and seat in the carb you can buy a carb kit and replace the needle and seat and it will stop leaking
make sure not to bend the float
Jul 19, 2014 | Polaris 2004 Sportsman 500 H.O
Replaced faucet cartridge but can't seat stem properly
It sounds like you might be missing a part. Check your list for all included parts. All parts are critical.
Sep 03, 2017 | Danco Faucet Stem
I have a serious kitchen sink leak from the cold water faucet. I've replaced all the parts that are replaceable: spring, washer, cartridge. It's a simple job and i am fairly sure that i did it...
If it's a Delta-type faucet, disassemble it and make sure that the little rubber "cup" seal is properly seated on the spring and in the seat. It's fairly easy to get one of them in slightly crooked, which will leak like the dickens. If it doesn't want to go into the channel properly, you can use a tiny dab of petroleum jelly (Vaseline) to lubricate it.
Oct 01, 2017 | Delta 2402 Classic Two Handle Kitchen...
Our Kohler K-454-3S is leaking when we shut it off.
replace the (either) O rings or washer, if its a washer setup I recommend replacing the seat also you can click on this link to see a normal repair for your problem ,, http://www.youtube.com/watch?v=ubp2W-3thOo Please take a moment to rate my reply and research for your problem,, Thanks Good Luck
May 08, 2011 | Kohler K-454-3S-AF Memoirs+ Widespread...
I have the 8" version. Does it come apart? I
the 8 inch version has 1 cartridge for hot and one for cold..shut off water.remove handle...unscrew metal retainers...these hold in cartridges....they ride in notches in metal...put in as you pull out 1 by 1..under these you should have 1 spring and 1 rubber seat replace those also if needed...sometimes easier if you do seats and springs if you have drips...cartridges rarely leak...good luck
Feb 20, 2011 | Danze & 4" Round Sunflower Showerhead -...
Drips after it is shut off
The shower valve will continue to leak until the seat and springs are replaced. here is a link that shows you how to make a repair. click on link and then seats and springs replacement.
http://www.deltafaucet.com/videogallery/index.html?filter=howTo#vid-ReplacingSeatsAndSprings
Dec 29, 2010 | Delta & Single Handle Shower Faucet
Leaky shower head
If you replaced the seats and springs and the problem continued you may need to get a whole rebuild kit including the ball and replace that one as well
Jun 27, 2010 | Delta & Single Handle Shower Faucet
Plumbing Logo
Top Danco Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Danco Plumbing Expert? Answer questions, earn points and help others
