Question about Maytag Stove Cooktop 74009086
Maytag stove says feature not available
Stove feature says not available
Maytag gas stove natural gas to LP conversion
The Maytag dealer can sell you the needed orifices to do this conversion.
Jul 17, 2016 | Maytag Stove / Oven / Range Cooktop -...
Is there something available to convert a hardwick propane stove / oven to run on Natural gas?
Should only be a matter of changing the jets, see a gas fitter if they can be changed.
Dec 20, 2015 | Maytag Crosley Hardwick Caloric Kenmore 8"...
N I fix my stove when its says 5A6 on my maytag stove
all I find is something about the sabbath making those units almost useless no non jewish people on sundays . one person changes the clock to a different day
Oct 13, 2014 | Maytag Stove Cooktop 74009086
What size breaker do I need for a maytag stove modle per4310baw serial # 14508789cl?
Go to the Maytag website on the internet and request the owner's manual for your model. It should have everything you need...download it!
Dec 25, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag stove
look on the internet they might help you.
Nov 28, 2012 | Maytag Stove / Oven / Range Cooktop -...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Dec 07, 2007 | Maytag MEC5430BDS Electric Cooktop
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Maytag Stove Cooktop 74009086 Logo
56 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
