Question about Kenmore HE2 Plus Front Load Washer
Locating water senser
How do I get to it
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 15, 2015
Coolant light is always on in my Ford Escape 2003
Did check for any codes? go to auto zone it is free.
Mar 23, 2017 | 2003 Ford Escape
Why is there water in the mass air flow senser area?
how much water ?? is it not condensation. dry it off and try again
Nov 17, 2011 | 1998 Ford Windstar
3.5v6 tempt gauge is not moving as engine warms?
Coolant temperture senser can be unplugged or bad. Coolant can be too low to touch senser. Coolant can be too much water and is'nt circulating as it's frozen and where the senser is it is still cold. The senser is in the left rear of the engine facing the firewall it has a two wire weathertight connector unplug the senser and with a papaer clip ground the wire and look to see the gauge go all the way if it does the gauge and wire are good and the senser or the water getting to it is'nt hot.
Jan 04, 2011 | 2004 Chevrolet Malibu
Replaced the water pump on 96 nissan maxima. timing did not get messed with at all. i had pulled the timing cover but the chain looked good and there was no way it could have jumped time. my obd scanner...
Sounds like you missed connecting something back up. The Knock senser won't make it not run it'll just not let it run at peak power. The OHMs on the sensers just need to be close and your old senser may be just fine. The senser watches a reluctor wheel go by. Did you put it back on? did you put it right side up? It'll fit backwards but it won't line up with the senser.
Oct 27, 2010 | 2001 Nissan Maxima
1994 buick lasaber wont start no spark why and what is it
if this is the 3.8 they have a problem with the cam shaft magnet falling off the timing gear if you pull the senser and turn the motor over by hand you can feel if the magnet is still there the senser is on the front of the motor above the water pump it also has a crank shaft senser behind the balencer
Oct 15, 2010 | 1994 Buick LeSabre
Light came on instrument panel. looks like a water pump light.
bet it's the low coolant light. There's a senser on the side of the raditor that tells if the coolant is low and it'll come on if there's straight water in the cooling system too it'll come on if the coolant is low it'll come on if it fails and all of these are as common as the other. Sometimes you can disconnect and reconnect the senser and it'll reset ifthe raditor is full of coolant but it can go bad too just as often, Sometimes you can just unplug it and it'll not work but you;ll not know when your low if you do. New sensers are dealer idem.
Sep 17, 2010 | 2005 Ford Mustang
I need a diagram of my fiat Cinquecento's engine - overheating probs with the radiator. I have replaced the rad cap, no difference. I'm putting water in every time I use it. It's a 'N Reg'. Been told it...
hi ok i can help with this problem u need antifreez cause water evporates faster, then and u need to check if the senser is bad or rust with water here have this digramsm-v1-10-19.jpgeck thermal senser that
Aug 06, 2009 | Fiat 124 Cars & Trucks
Mercedes sl300 fan switch
There are several applications that this water pump is designed for. I know that primarily there are 2 switches used and they install in the t-stat housing portion of the water pump assembly. I believe that there is a single pole senser for the gauge and either a 2 or 3 pole senser for the aux fan and poss.compresser shutoff. I hope this is an o.e.m. water pump because the after market ones don't last as long and have higher failure rate. If it is an after market I would be suprised if the switch fit. If the switch came with new pump install original switch into new unit with new crushwasher. I'm assuming that you are talking about the aux. fan because the fan clutches are all hydraulic with the exeption of the 102 engine wich is a four cyl. Also there are some plugs that need to be transfered and they are all plugging up bores for coolant temp. sensers. If this fan switch won't go into the original pkace try another senser hole and plug up the other one. it doesn't matter wich port the senser goes into as long as the thred is the same. There sometimes a small hose that atatches to the back of the pump if not the pump comes with a plug. Like I said ther is several different applications. I'm an M.B. tech- if you have any more questions just post them and I will look at them
Mar 24, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
An engine fan contiues to run after the car is turned off
yeah it runs to cool down the engine coolant and engine
Dec 20, 2008 | 1993 Saturn SW2
Kenmore HE2 Plus Front Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
