Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Husqvarna YTH 2448 charging/starting problems.
This is a 2005/6 mower with the 24hp bs v twin ELS engine. The mower stopped charging the battery last year and I noticed the regulator was damaged/melted. Our dog chewed through the wires around the same time. Wires were patched back and the regulator was replaced from Sears parts, but still no charge on the ampmeter. It has the electric blade engagement which shows a big draw on the ampmeter when its engaged. I'm somewhat familiar with stators since thats what my old Mercury 500 has, but I'm not sure what could go wrong with one or how to get to this one. I see the two black wires coming out from it, but thats about all I can see. It's a big pain having to jump it off my boat battery every time I use it or it cuts off from the charge being so low on the battery. The mower mows great and I love the hydrostatic transmission, but not happy with the engine other than that it is powerful... when it runs.
  • jamieei Jun 15, 2009
    The fuse never even blew...
I have just came through the same scenario. I replaced the regulator, but that wasn't enough, I also had to remove the flywheel which exposed the altinator, the altinator was burned up. I don't know why, or how this happened. I went to the local Briggs and Stratton dealer and bought a new Altinator for $65.00, installed it and viola! charging again.
The whole job took about 3 hours, most of that time was finding the pullers and setting them up to break the flywheel free.
Good luck...
Posted on Jun 20, 2009
Testimonial: "Same problem, same solution. thanks"
  • 4 Answers
Please don't jump start your mower and mow with a low battery. This is a very expensive mistake. If the mower is not producing enough charge, then you will have low current going to your electric clutch. It will burn up in short order and you will be buying a new one for a couple hundred bucks--Most definately won't be on warranty.
Posted on Jul 08, 2009
  • 867 Answers
Work your way from the battery back, like make sure the connection is good. something may have fried besides the regulator, is there no fuse anywhere?
Posted on Jun 14, 2009
Can I swap the motor from a Husqvarna YTH 180 and put it in a Husqvarna YTH 1848 HP?
The 1848 uses an 18 HP Twin cylinder engine. Mine is a Kawasaki but a similar 18 - 21 HP Kholer will also work. Can't see a problem
Nov 06, 2014 | Husqvarna Garden
First service my YTH 2448
First service is engine oil change and oil filter if fitted, air filter change, in line fuel filter change, check sharpen blades, re tighten all externall nuts and bolts, no need to change the fluid in the hydro unit, just check for any external leaks, allow a couple of hours to do this.
Apr 04, 2013 | Husqvarna Garden
On a Husqvarna 2005 ELS 2448 riding mower, PTO switch burns up, and wont blow the fuse first? Why?
I used to see this on the Kawaski engine machines with an electric clutch, they put a diode between the two clutch wires so as so as to stop any electrical feed back throught the clutch, when the machine is running without the clutch engaged it can turn into a generator.
Oct 17, 2012 | Garden
My husqvarna YTH2448 with BS 24OHV ELS725 started knocking and leaking oil from right side. I guess it threw a rod? I want to get another 24HP motor and replace it. Will any other motor's bolt pat
most all motors will boltt up u need to make sure the crank is the same diameter and length besides even if it didnt bolt right up u can always drill new holes
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
Husqvarna yth 2448 shuts of when i let the cluch out, same thing when I engagge mower blades
check the safety switches start with the one on the clutch it is a double switch
Husqvarna YTH 2448 mower PTO switch is getting hot and melting the plastic internal parts. Any ideas on what is causing the overload? The mower deck will shut off when the switch melts and the push/pull...
The problem with an electric cluch is that when the engine is running without the clutch engaged the clutch can turn into a dynamo which then passes power back up to the switch, most machines will have a diode close to the clutch in the wireing to stop the current flowing back to the switch, so i guess the diode is bad on your machine and power is flowing back to the switch and melting it,
Nov 08, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Jul 15, 2009 | Husqvarna Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
2,450 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
