Question about Saeco Hot Buy Talea Touch Plus Automatic Espresso Machine Touch Screen Display
Talea touch plus
Machine is jammed up
dutchman05
  • 487 Answers
SOURCE: Saeco Talea Ring Plus
ok with a machine you have already for a while :
Putt descaling solution in the machine. unplu the machine and open the watere valve. Aftre about 2 days it should have desolved.
BUT>>>>>>>>>> what also can be is that the valve on the bottom of the water tank is not working.
Fill it a little and wiggle the valve until water comes out and than try again.
Priming normally goes.
Water in tank. push water button and open valve.
Posted on Jun 03, 2008
SOURCE: HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Posted on Apr 11, 2009
EsWorld
  • 1618 Answers
SOURCE: Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Posted on Aug 28, 2009
  • 81 Answers
SOURCE: talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Posted on Jan 24, 2010
SOURCE: possibile avere schema impianto elettrico saeco talea ring plus
Possibile avere schema impianto elettrico saeco odea go
Posted on Dec 30, 2010
My saeco talea touch wont steam out of the wand, it makes the noise like it is steaming but the steam is coming out of the bean hopper and the grind tray area
Your delivery pipe has been disturbed at some point and has dislodged or blown out the O-ring seal, or maybe careless assembly of said pipe seal, if under warranty, take it back.
Oct 19, 2014 | Saeco Hot Buy Talea Touch Plus Automatic...
Saeco talea grinder is starting when you start the machine
this sounds like the machine simply needs a good cleaning due to grounds jamming the switch in place
Sep 05, 2014 | Saeco Talea Ring Plus Espresso Maker with...
Talea giro plus. csan't exit descale cycle
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
I have a Saeco Talea. The drip tray will go up
Probably the touch pad is faulty. Before we decide that make sure the bottom touch area is dry and nothing sticking on to it.Can be check by removing the 2 screws underneath.
The worst case senerio will be the CPU which is not receiving the signal from the touch pad.
Jan 10, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Out of service [4] out of service [87] restart to solve the problem SAECO TALEA RING PLUS
Hi...itis not self testing..in otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
Dec 04, 2009 | Saeco Talea Giro Espresso Machine
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
The selction ring on the Talea Ring Plus doesn't work anymore, does anyone have a clue?
I had the same problem, after dismantling the machine I found that the touch detector is glued to the back of the plastic front panel and had become detached, so that it was too far from the operator's finger to work. Reattached with fresh glue, checked connection to main board, works perfectly now.
Dec 26, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Hot Buy Talea Touch Plus Automatic Espresso Machine Touch Screen Display Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
