Question about Pioneer SFCRW230S System
Subwoofer doesn't work everything else does.
What could be wrong?
Car amplifier stopped working.
what gauge wire are you using
Apr 24, 2012 | Car Audio & Video
I have a 12 inch rockford fosgate subwoofer. It just completely stopped working. cosmetically, there is nothing wrong with it to the ***** eye. My amp works just fine, but the sub doesn't do...
First, switch channels to make sure it's the sub. Check to make sure the tensil leads that go from the + and - posts to the voice coil have not come loose. If that's not the case, the voice coil may have failed.
Aug 31, 2011 | Rockford Fosgate Car Audio & Video
Doesn't heat up but everything works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';'
May 18, 2011 | Emerson Black Microwave Oven
THERE IS NO SIGNAL COMING FROM THE SUBWOOFER, IT IS CONNECTED TO A SONY AMPLIFIER IN THE SUBWOOFER JACK, AND CONNECTED TO THE SUBWOOFER IN THE LOW LEVEL INPUT. THE SUBWOOFER IS CONNECTED TO THE MAIN, AND...
With everything connected correctly there could be a couple of possible problems:
1. If your receiver has on screen display capabilities, you may need to turn the subwoofer output "on"
2. If your subwoofer has speaker wire inputs/outputs, you could run speaker wire to it, then to your speakers & test if the subwoofer is working... hence verifying that the receiver has a function to turn the subwoofer output on/off
3. The cable between the subwoofer & receiver could be bad. Try another cable.
Mar 16, 2011 | Audio Players & Recorders
Its working only in direct & stereo mode
maybe you need to replace a fuse?
is it hooked up correctly
Apr 23, 2009 | Denon AVR-1508 Receiver
Subwoofer does not turn on when playin usb or cd or aux
I have the same problem..Have you guys sorted it yet?
Mar 12, 2009 | Car Audio & Video
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Confused with answer....
I recomment you ask this question from the expert named ginko. thanks.
give me a fixya rateing anyways thanks :)
Apr 06, 2008 | Bose Acoustimass 15 System
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Cerwin Vega V-10S Subwoofer doesn´t sounds good
dear "rai17"
This, to me, is most likely the voice coil inside the driver rubbung against the yolk plate, or possibly the spyder slapping the metal plate underneath it, or the amp-(if it has one?) getting tired. this can occur from poor build quality, or playing the subwoofer too loud. depending on how much it cost you, you may want to get it repaired(voice coil re-alignment or something or new amp). But the way it seems, it is probably the driver itself. subwoofers get looser as they break in. This one may have been over-broken....sorry
I hope this helped clarify what is happening!
Oct 09, 2007 | Cerwin Vega V-10S Subwoofer
Pioneer SFCRW230S System Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
