Question about Canon ImageRunner C3080i Color Copier
E000748-4311 copier shows e000748-4311 even replacing RAM & BOOTRAM then where could be problem persis and how to fix this error in the machine
My kyocera 4050 is showing cfb31. How do I solve the problem?
the error is a system error if the following error code is displayed. When an error has occurred, clear the error by turning the main power switch off then on.
These error type should be reseted by restarting the machine
CF1XX, CF2XX, CF3XX, CF4XX, CF5XX, CF6XX, CF7XX, CFAXX, CFBXX, 0xFBXX
Best regards,
Marius
Nov 14, 2016 | Kyocera Km-4050 With Feed, Finisher, Bank,...
Samsung scx6555n showing error #31-007
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Sep 13, 2012 | Samsung SAMSUNG SCX6555N LASER...
Display shows RAM ERROR on Xerox Phaser 8860
I would first try to inspect and possibly replace the ram. On the back of the machine there are two thumb screws holding on a metal plate. Remove the two screws to access the ram. You can remove the ram and try the second ram slot if it is unused. (check the video at 2:45 to see what this looks like) If after replacing the ram and trying both ram slots the error continues you most likely need to replace the Electronics module (MFP part# 084K36560, non-mfp part# 084K36550). Here is a video that shows you how to replace that part. (video is of a 8500 non-mfp version so it is a little different but still similar). Good luck, and thanks for using FixYa!
Sep 01, 2011 | Xerox Phaser 8860MFP/D - Multifunction -...
Hello, I have a Xerox 4510 DT that shows the error: RAM ERROR. I have had the users shut down the machine, wait a minute and then restart but the error still shows. What else can I have the user do?
You can try inspecting and moving the ram to the other RAM slot. The 4510 image processor board has 2 ram slots, so one of them should still be unused. To access the ram you must remove the right side cover. Its possible changing the slot the ram is in will fix this, if it does not the next step would be to replace the ram. Part# 133K27760 for 128MB. Finally, if after replacing the RAM the error continues you would need to replace the image processing board. (part# 960K41806). Hope this helps
Aug 01, 2011 | Xerox Phaser 4500 Printer
We have replaced the belt in oki c5950 printer and the warning light is still on and displaying Belt life error
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
May 10, 2011 | Office Equipment & Supplies
The fax shows a messages saying "open heat error"
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
Jul 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
My Printer is showing scanner error 6 on the
you may have a problem in your cartridge, replace it first and then replace the scanner unit
Mar 30, 2010 | HP LaserJet M1005 Printer
Need software hdd for3300/3320i and bootram software
im a canon Tech,
you need a program to reload the new firware and only canon techs have it its pretty complicated to do if you have never done it before.
you can try and do a search for service support tool, that is the program you use to upload the new firmware but even if you had the service tool you would not be able to get the firmware, only canon techs have it, either get to know a canon tech your mates with or just ring canon service and get a tech to do it.
Canon Technician
Feb 19, 2009 | Canon imageRUNNER C3200 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
Canon ImageRunner C3080i Color Copier Logo
old marine
old marine
