Question about Bikemaster 1999-2010 Polaris-victory All Models Motorcycle Deep Cycle Gel Battery
Break light stays on when bike is off
No apparent direct wiring to back brake
    Sergeant:
  • 331 Answers
There is a switch at the rear brake pedal and at the front brake handle.
Disconnect the wire from both to check witch one is bad.
Second point, are you sure it's the bracke light and not running light?
There is a position on your contact key where engine is of, but park-lights stay on...
Posted on Mar 08, 2015
Hyundai trijet just had abs ring changed on passenger front now abs light stays on and hand break light stays on. Help.
If a wire was broken replacing the reluctor ring, this would be the ABS light. Not the brake light. Check the brake fluid, check the E brake pedal/handle. The rings do break, I just weld them back in place. If they are gone, it gets a new axle.
Sep 11, 2016 | 2005 Hyundai Trajet 2.0
Brakelights stay on
Are you talking about the brake lights in the back, or the brake warning light on the dash ?
If the warning light is on, have you checked the fluid level in the master cylinder ? Is the parking brake on ?
Jan 24, 2013 | 1995 Dodge Ram 2500
I have a 2000 sportster my front light does not work and my brake light does not stay lit but when brakes r applied brake light comes on and turn signals all work can someone help me?
Short to main accesories which is dash lights headlamp and tail Lamp not the break lamp it's prolly on the ground wire side since some lights still work ther getting juice but the ground that compleats the circuit to the break lights gets there through the break switch ok but the ground from the key on switch isn't getting to the constant on light start at the try to run new grounds to anyplace and if the lights com on its in the harness and u start tracing it down when the bike is striped of tank and sheetmetel it will be Easter to find look at the harness connectors for green oxidation and loos fitting wires
Mar 14, 2012 | 2004 Harley Davidson XL 883 Sportster
Whyis my break light staying the bike is a 2006
The front brake light switch in located in the throttle switch housing. When you pull the front brake lever, it pivots and allows the switch to make. Sometimes the brake master cylinder and the front switch housings move and cause this problem. Loosen the master cylinder bolts holding it onto the handlebars and make sure it's slid down tight against the throttle switch housing.
If this doesn't solve the problem, you may have an electrical problem that you'll have to trace out and find the problem. You'll need a wiring diagram for this. There are two switches in the system that controls the light. I've already talked about the front switch. The rear brake switch is a pressure switch located somewhere along the metal line that comes out of the rear brake master cylinder. Sometimes these switches go bad but rarely. Having an electical problem on a bike this new is unusual as well. I don't have a wiring diagram for this model. Good Luck.
Apr 12, 2010 | Harley Davidson FLSTC Heritage Softail...
Rear brake light stays illuminated on my trail bike
you will have to check the switch which should be situated at the back of the pedal . the switch may be over tight and causing the light to come on .
Check also that the wiring may be swapped as the tail light may be using the brake lightbulb .
Oct 13, 2009 | 2005 KTM EXC 300
My brake lights stay on after turing off my 2004 Buick Rendezvous
The brake light switch is located under the dash - if you'll look at the brake pedal and follow it up until you see a plastic cylinder with an electrical connection - that should be the brake light switch - they are often difficult to remove (they are in a bad place and hard to get to - sometimes they are threaded as well - sometimes use a clip to hold them in) They have a push-button that contacts the pedal arm - When the brakes are off, the switch is "electrically open" and has no internal connection (no brake lights) when you push the brakes Switch is now "electrically closed", the switch button releases and the switch makes a connection internally to activate the lights - yours has either lost it's mounting and no longer contacts the pedal arm, keeping brake lights on - or has an internal short - keeping them on even when the switch is activated .....This often means that your brake lights do not work correctly (or rather stay lit at all times while you are driving) thus, a definite safety hazard - remove the wiring pigtail, remove and replace the switch and plug the wiring back in - have someone check that they are now working correctly - or use a mirror - (sometimes, on some vehicles there is a rubber plug that fits into the brake lever where it contacts the switch - this plug can fall out or break apart and cause the same problem, so when you get up under the dash to look for it, ensure the parts are there, and I usually activate the pedal with my hand and visually check the mechanicals to ensure proper operation and part presence....) The switch can also be mounted directly to the arm and moves with the pedal - or mounted on the car and is depressed by the pedal - I've seen it done several different ways so use your common sense and you'll be just fine...
Aug 22, 2009 | Buick Rendezvous Cars & Trucks
Brake light stays on causing cruise control not to engage. 2005 road king clasic
hand break switch was broken (inside the wire housing) not allowing the hand break lever to deactive, therefore causing the brake system to stay on.
May 17, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Brake lights stay s on
check the wiring harness from the break light to the main harness , sounds like the the wire is moving and possibly shorting on the frame..
May 10, 2009 | 2008 Honda GL 1800 Gold wing Deluxe
Brake lights
The taillight should be on at all times. The brakelight should come on when the front or rear brakes are applied. Start by disconnecting the front brake light switch then the rear to see which switch is broken. Also check the bulbs. I have seen them short out internally. The filament inside the bulb break and contacts the other circuit.
Nov 20, 2008 | 1977 Honda GL 1000 (K2)
Bikemaster 1999-2010 Polaris-victory All Models Motorcycle Deep Cycle Gel Battery Logo
250 people viewed this question
Top Bikemaster Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Bikemaster Boating Expert? Answer questions, earn points and help others
